Kitchen sink leaking to outside wall
Discussion in 'Drain Cleaning' started by Fisherman, May 13, 2009.
  1. Fisherman
    Fisherman New Member
    May 13, 2009
    Caulifornia
    Hi Everyone,
    I have a strange plumbing problem, was searching the internet for a clue and found this forum. It looked like a nice bunch of folks so I registered.
    Here's my problem. My house is about 25 years old. The sink is a porcelain, double basket, with a waste disposal under the left side, and a dishwasher connection.
    Earlier today my wife was washing dishes; she had the stopper in the right side, full of water, and the faucet running into the left side for rinsing. After she let the water out of the right side she walked out onto the concrete patio and there was a water puddle on the concrete. The outside wall is stucco, and right down near the concrete there is a little hole where I can just barely see the down pipe from the sink drain.
    After coming home from work I was able to recreate the problem by filling the right side with water, run the faucet into the left side, then release the right side into the drain. Then, through the little outside hole, I could see water dripping down from inside the wall. It's not coming from the pipe, at least not in the area of the hole.
    I found this web site that talks about an Air Vent on top of the down pipe:
    http://www.hammerzone.com/archives/kitchen/sink/drain/02/replace_old.htm
    Scroll about half way down the page to see what I'm talking about.
    What I'm wondering is, do you think I might have one of these in the wall, and the water is backing up into the down pipe and coming up out of the Air Vent? I can see this happening if the drain is partially clogged.
    I checked all of the plumbing under the sink, it's all dry. I can't think of anything else.
    Oh, and by the way, all of the pipes (except for the down pipe from the right sink basket) are PVC.
    Anybody have an idea what's going on? I can supply pictures, if that would help, just let me know.
    Thanks,
    Fisherman
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    If it's an AAV it should only allow air in and seal itself afterwards. Although they fail quite readily and that is probably why they come threaded! Of course it should not be installed in a wall or any concealed location but hard to tell without actually being there.
    A pipe transition is a more likely culprit with an elastomeric gasket joining the two. If it slipped off then the two pipes (PVC to glavanized, etc) would no longer be sealed allowing waste to flow through but rather out.
  4. 3m
    3m New Member
    Mar 3, 2009
    NY
    The line may have a nail or screw in it to, its hard to say, or a joint that wasnt glued or was but is leaking. They sell a scope camera that you can drill a small hole in the wall and take a look inside but they are expensive and you will probably need to call a plumber to locate the leak or tear the wall open so you can see where its coming from
  5. Fisherman
    May 13, 2009
    Caulifornia
    I suppose that's where this is going, I was just trying to convince myself that's it's just a restricted pipe that could be cured either with a snake or chemicals. Oh well...
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Kitchen sink leaking though outside wall
    see the above post;
    there was also a time in calif, when there was a problem with a b s plastic sewer pipe
    but more then likely it's just a screw in pipe, like when you get one in a tire but it does'nt go flat right away, it just taken time for the nail or screw to rust out ! !
    But it only shows up when you run lots of water though pipe puts water out
    take a hammer and bust out the stucco around the leak !
    Make a good size hole to expose at least a couple of feet of pipe then take pictures of area and post here then we can tell you how to fix pipe then
    i will tell you how to fix the stucco
    macplumb 777 calif. Lic contractor since 1989
  7. hj
    leak
    I have had many situations where the tee inside the wall has cracked causing the symptoms you describe.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It does indeed sound like a pipe problem inside the wall. Things need to be opened up to find it.
  9. Fisherman
    May 13, 2009
    Caulifornia
    Okay, here's a new twist to the story. The bottom of the cabinet under the sink is very damp. It's been wet before, but before I always had found plumbing leaks under the sink baskets. But this time, no leaks under the sink. So, I'm thinking that water from the leak in the wall is getting into the cabinet somehow. So, today I'm going to rip out the cabinet bottom. It needs to be replaced anyway. I'm going to do all I can to not rip a hole in the stucco, if at all possible.
    Here's a photo of the cabinet under the sink:
    [​IMG]
  10. Fisherman
    May 13, 2009
    Caulifornia
    Yuk!!
    Okay, here's what I found. The joint right above the clean out plug is leaking, and the joint right above it is leaking on the other side, on the stucco side of the joint (the third photo). I can feel wetness back there with my fingers. Here's some photos:
    [​IMG]
    [​IMG]
    [​IMG]
    How hard is this to repair? It looks like a bigger job than I'm willing to tackle.
  11. 3m
    3m New Member
    Mar 3, 2009
    NY
    cutting that out and replacing it isnt a big deal but it is abs so you either need to replace it with abs or use ferncos and pvc. If you dont feel comfortable call a plumber and make sure its done right.
    [​IMG]
  12. Fisherman
    May 13, 2009
    Caulifornia
    Calling a plumber...
    Any plumber in my area that wants the job? :)
  13. kingsotall
    Aug 17, 2008
    Forgot to glue the fittings! Wonder how it passed testing¿
  14. Fisherman
    May 13, 2009
    Caulifornia
    It looks like there is glue on/in the joint. What's weird is, while running water down the drain and watching the joint, water just seeps right out through the glue! This pipe is only about a half inch from the outside wall. Where I live the temperature right on the outside of that wall gets up to 110 in the summer, and freezes in the winter. I'm guessing that the constant heat and cold over the last 25 years has taken it's toll. :(
  15. kingsotall
    Aug 17, 2008
    I dunno. Once the cement adheres to the fitting to pipe it is solvent welded. Something screwy happened there on top out.
    BTW, that is awesome you got your smiley up there fishing in your name! :cool:
  16. Fisherman
    May 13, 2009
    Caulifornia
    I went searching for a fishing avatar, found that smiley, and voila! It worked!
  17. MASTERPLUMB777
    Aug 6, 2007
    Texas
    NO IT'S NOT A GLUE PROBLEM OR ANYTHING ELSE,
    IT IS A PIPE PROBLEM ! ! SEE THE FOLLOWING LINK ! ! !
    http://www.abspipes.com/
    AND ALSO THIS LINK http://www.abspipes.com/id.html
    THE ONLY WAY TO FIX IS TO CUT OUT AND REPLACE !
    DO NOT REPEAT DO NOT USE ANY GLUE ON ANY OF THE OLD PIPES ONLY USE METAL JACKETED PIPE COUPLINGS !
    YOU CAN HOWEVER GLUE TOGETHER ANY NEW PIPES AND FITTINGS
    AS A CALIF, PLUMBING CONTRACTOR I WAS VERY INVOLVED IN FIXING THESE TYPE
    OF PIPE PROBLEMS IN THE LATE 80'S AND EARLY 90'S IN THE SO. CALIF. AREA BUT THIS PROBLEM WAS WIDESPREAD THOUGH OUT CALIF,
  18. plumbingskool
    plumbingskool Retired Tradesman
    Feb 25, 2008
    Not Sure ;-)
    NY
    Agreed 100% - Go big or go home,
    Tear the wall open as Jerry and the others say:)
  19. kingsotall
    Aug 17, 2008
    Did you not see the pics after Redwoods post you quoted¿
  20. hj
    leak
    It is not a bad joint, it is the cracked pipe I mentioned originally.
  21. MASTERPLUMB777
    Aug 6, 2007
    Texas
    Kitchen drain leaking
    Yes i know redwoods post,
    did you check the links i posted ? ?
    That is exactly the symptoms i was talking about !
    As soon as i saw the pictures of the problem i knew that confirmed what
    i posted !
Similar Threads: Kitchen sink
Drain Cleaning Upstairs toilet & shower drain into kitchen sink. Basement sink drains ok to sewer Mar 28, 2016
Drain Cleaning Clogged Kitchen Sink w/ Waste Disposal Unit Dec 6, 2015
Drain Cleaning Water flows up vent stack, rather than out waste pipe (kitchen sink) Jul 7, 2014
Drain Cleaning Constantly clogging kitchen/laundry sinks Dec 16, 2013
Drain Cleaning HELP! Kitchen Sink Draining Slow...Can't Find Clog Mar 14, 2013
