Kitchen sink backfeeds
Discussion in 'Drain Cleaning' started by msehler, Jun 10, 2008.
  1. msehler
    msehler New Member
    Feb 20, 2008
    Kansas
    Sorry for the dumb question, but I have very very limited plumbing experience, and it's all getting the water to the house, not getting it out.
    My house was built in 1975 and the sink is a side by side with garbage disposal. Lately it has been backing up, and when I hit the garbage disposal it fills up the opposite side. It is also very slow to drain. I took a quick peek under the sink and the drains don't look immediately connected. I tried drain-o down both drains with little to no improvement.
    Where should I start?
  2. hj
    drains
    With a good plumber who has the necessary drain cleaning equipment and the experience to use it properly.
  4. jadnashua
    Draino doesn't work that often, plus, it can eat up a garbage disposal. It also can mess up a snake or injure a plumber (or you) if the pipes need to come apart for cleaning. You have a clog, and it will probably take a snake and a plumber to fix it. Stop putting chemicals down the drain.
  5. Sandpiper Plumbing
    Sandpiper Plumbing Plumber
    May 4, 2008
    Northern by birth, Southern by choice
    Draino disolves grease and hair. Period. It won't disolve the little bits of food stuck in the pipe from your disposal or correct backpitch problems or anything like that. HJ is right, call a local plumber with drain cleaning experience and good equipment. You'll probably find that a local pro costs less than the national "Rooter" chains
Similar Threads: Kitchen sink
Drain Cleaning Upstairs toilet & shower drain into kitchen sink. Basement sink drains ok to sewer Mar 28, 2016
Drain Cleaning Clogged Kitchen Sink w/ Waste Disposal Unit Dec 6, 2015
Drain Cleaning Water flows up vent stack, rather than out waste pipe (kitchen sink) Jul 7, 2014
Drain Cleaning Constantly clogging kitchen/laundry sinks Dec 16, 2013
Drain Cleaning HELP! Kitchen Sink Draining Slow...Can't Find Clog Mar 14, 2013
