SidDIY
Hi,
I have a Kinetico Quad 51 which has 4 mini tanks (two sets of one on top of the other tanks). It looks similar to the Kinetico model 4040 which can be checked online. The upper two tanks carry resin while the bottom two tanks carry carbon. I have seen videos about replacing resin in a single long tank on other Kinetico models. But for this model with 4 mini tanks, do I need to separate the upper and lower tanks in one set and then replace the resin and carbon respectively? Or can these upper and lower tanks not be separated / taken apart? And in that case do I have to first pour in carbon into the lower tank via the upper tank followed by the resin in the upper tank? Any guidance or videos or instructions would be appreciated.
Thanks,
Sid
Thanks,
Sid
