kinetico model 30 help
Discussion in 'Water Softener Forum, Questions and Answers' started by hattrick37, Apr 26, 2009.
  1. hattrick37
    hattrick37 New Member
    Apr 26, 2009
    I had to manuel regenerate the water softner and it wont regenerate on its own. The water taste salty and is cloudy. I cleaned the brine tank completly out and put new salt in it. When I run the water in the house I can hear the gears turning but wont regnerate and also the brine tank is that suppose to have water in it at all times or is the water suppose to drain out.Help dont know much about water softners and how they work. Ive been doing alot of reading but I havent found anything to in depth.:confused:
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Neither do I know very much here, but I do have the same softener. The water passing through the unit turns the gears that turn the valves during regeneration. So, it should be regenerating if the gears are turning, and I do know the entire mechanism needs to be protected by a water filter to keep things from getting plugged up inside.
    When my brine tank is low on salt, I can see 3 or 4 inches of water in the bottom. But when there is plenty of salt in the tank, I never see any water.
    I have also done a lot of searching without ever finding much info for my Kinetico, but there are some folks here who know a lot about them.
  4. hj
    If you have a problem with a Kinetico, you probably have to call them, because, at least here, they do not sell parts or service manuals for them.
Similar Threads: kinetico model
Water Softener Forum, Questions and Answers Kinetico Model 30 won't stop draining... Jan 10, 2016
Water Softener Forum, Questions and Answers Kinetico - Model 51 - Will not draw brine Jun 11, 2015
Water Softener Forum, Questions and Answers Kinetico Model 60, 1 tank now very loud during brine rinse Mar 10, 2015
Water Softener Forum, Questions and Answers KINETICO Model 60 PAWL LAYOUT Sep 15, 2014
Water Softener Forum, Questions and Answers Kinetico Model 60 Toothed Disk Operation Sep 12, 2014
