Kerdi Membrane
Discussion in 'Shower & Bathtub Forum & Blog' started by DanMcD, Nov 21, 2009.
  1. DanMcD
    DanMcD Member
    Jun 19, 2005
    Dayton, OH
    Do most plumbers install Kerdi membranes before tiling shower/bath walls or even behind solid surface and fiberglass walls?
    Dan McD
  2. Cookie
    Cookie .
    Oct 7, 2005
    I did, I did it myself, bath walls.
    But, I am NOT a plumber nor do I ever want to be a plumber.
  4. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    I don't think plumbers install the membranes ( I know I don't). They install the drain bodies but after that it's up to a tile guy or gal.
  5. jadnashua
    The only time Kerdi makes sense is if you are going to tile the shower. It makes no sense using it behind a premade panel. It's a very good system, and by system that means you need to use all of the various parts, the primary one includes the drain. The plumber should be able to install the drain, but the location and level is critical on the drain since it has such a large diameter - a little error in plumb will make the edge stick up and look really funky. Since the drain is plastic, it needs to be supported well without any tension on it by the shower pan's deck mud (or the foam pre-sloped pan). This bond isn't super strong, so if the drain isn't level, you'll have problems.
    If you want a lot of discussion about Kerdi showers, check out www.johnbridge.com or review the product at www.schluter.com. I've remodeled only two bathrooms, and used it in both. Like it.
  6. eurob
    eurob master tile and stone installer
    Feb 16, 2013
    Montreal
    How this could differentiate you -- seasoned Kerdi installer -- with someone that is installing Kerdi for the first time , with no other experience in tile and stone trade related ? Both ID card carriers -- approved Kerdi installers ?! -- after workshop completion course .......... maybe is something I am not getting right .
    What could you offer more ?
  7. dhagin
    dhagin builder:anti-builder
    Jan 22, 2014
    builder
    oahu
    Having a Kerdi "card" or having a contractors license is no guarantee that the contractor you hire is going to be fair, honest, respectful or competent. Ask around for references, ask other tradesmen you trust, check around on the internet and ask around at the supply houses. You'll learn a lot more about this so-called card carrying "contractor" from others than you will from them.
    Pay attention to how respectful this so-called contractor is of others, and you'll have some idea of how they will treat you as a client. :)
  8. dhagin
    Jan 22, 2014
    builder
    oahu
    I'll try this again - this post has to do with fairness, honesty, respect, and competence, not cards, licenses or codes. Of course your contractor should have all the necessary licenses and cards AND follow all applicable codes and laws.
Similar Threads: Kerdi Membrane
Shower & Bathtub Forum & Blog Purple or regular drywall with Kerdi membrane or Ardex 8+9? Looking at the best option Dec 14, 2014
Shower & Bathtub Forum & Blog The 8mil Vapour Proofing Show Down - Laticrete's HydroBan Sheet Membrane vs Schluter's Kerdi Jul 20, 2014
Shower & Bathtub Forum & Blog Custom's Kerdi Membrane Mar 13, 2014
Shower & Bathtub Forum & Blog Kerdi membrane install question. Mar 10, 2013
Shower & Bathtub Forum & Blog Kerdi Membrane VS Mapei Aqua Defense Jan 30, 2013
