Kenmore Ultrasoft 200
Discussion in 'Water Softener Forum, Questions and Answers' started by Jdog52, Jun 27, 2009.
  1. Jdog52
    Jdog52 New Member
    Jun 27, 2009
    My Kenmore Ultrsoft 200 is not producing soft water. I have followed the diagnostics on the Kenmore troubleshooting site and have found the brine valve is not sucking water while in the brine cycle. At this point the Kenmore animation informs me to contact a sevice technician. Can anyone help me beyond this point? The venturi valve has been cleaned, gasket replacedand is working.
    Thanks
  2. Gary Slusser
    Retired
    Sorry I can't.
  4. Jdog52
    Jdog52 New Member
    Jun 27, 2009
    Sorry to take so long to respond. I thought the isssue was solved, but it is not. No water out of the brine lins and venturi is making a sucking sound during brine cycle. After recharging manually, the water is somewhat softer for a day or so. I am guessing that I m getting a short supply of soft water through the cold lines. This softener is about 15 years old.
    Thanks
  5. Jdog52
    Jdog52 New Member
    Jun 27, 2009
    Yes, the water supply is chlorinated. On a 15 year old unit is it smarter to replace the unit?
  6. Gary Slusser
    Retired
    No. You shouldn't replace resin unless what you have is bad. Get some and rub it between a thumb and finger, if it is hard it's good.
    You need to fix the problem with it not regenerating right before you do anything.
  7. Jdog52
    Jdog52 New Member
    Jun 27, 2009
    OK. So what next? Venturi appears to functioning properly.
  8. Gary Slusser
    Retired
    Get a hardness test kit and see how much hardness is in the raw water and then the softened water. And when the soft water goes hard. Then decide if you want to replace the resin if it is bad and open up the tank and check the resin. Or buy a new softener.
    I don't know what else to tell you.
  9. Gary Slusser
    Retired
    How long resin lasts on a chlorinated water system is a function of how much chlorine is in the water.
Similar Threads: Kenmore Ultrasoft
Water Softener Forum, Questions and Answers Kenmore Ultrasoft 150 stuck in regen mode Jan 22, 2016
Water Softener Forum, Questions and Answers Guide to take head off of Kenmore Ultrasoft 275? Jul 28, 2014
Water Softener Forum, Questions and Answers Kenmore UltraSoft 480 - Regenerating/Drainin non-stop - - is it worth repairing? Apr 29, 2011
Water Softener Forum, Questions and Answers Kenmore Ultrasoft 425 Err3 Code Mar 10, 2010
Water Softener Forum, Questions and Answers Kenmore 3500 won't make softwater Mar 6, 2017
