Kenmore Ultra0Soft 200 or 250 Shutting house water off.
Discussion in 'Water Softener Forum, Questions and Answers' started by Airborne16, Jul 24, 2010.
  1. Airborne16
    Airborne16 New Member
    Jul 24, 2010
    Fort Hood, Texas
    My 7 or 8 year old Kenmore UltraSoft 200 (or 250) water softener appears to have shut my house water off, all of it. No toilets, sinks, fridge water dispenser, nada. I've confirmed at the street (main water valve) that the main source is good but the old water softener seems to be the culprit. I've unplugged the cord and replugged it in. I've pushed the re-cycle buttons, to no avail. What am I missing? Thanks. 254-220-3806. Ron (Airborne16)
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Check your service manual but it sounds like the valve is stuck.
  4. Gary Slusser
    Retired
    If it doesn't have a by pass valve, you cut it out of the plumbing and put the plumbing back together but.... how did you determine that it is the softener? More likely is a gate valve gate broke and closed or a washer came off a washer type valve and the gate or washer is blocking water flow.
    But it could be a blocked top or bottom basket in the softener is blocked up but that is a very rare thing that has to have a cause that comes in with the water. Has your water been dirty lately? Do you have a well or city water. With city water I can't guess what could block a softener.
    BTW, if you unplug the softener, it can not do a regeneration because there is no power to move the valve parts so it is just going to sit there not even knowing you pushed any buttons. It's like taking your battery out of the car or disconnecting it and sitting there turning the key to Start, On etc. and pushing the window and door lock buttons, and nothing happens.
  5. Gary Slusser
    Retired
    Say what!
    All residential control valves have an internal hard water by pass meaning that if you use water during a regeneration you get hard water, not no water.
  6. Airborne16
    Jul 24, 2010
    Fort Hood, Texas
    Thank you for the input. No, I did regeneration after it was plugged back in and nothing has changed. The brine valve isn't stuck; slides freely on its track. What other accessible valve might there be that I could troubleshoot? My Kenmore 250 (NOT 200) has a by-pass PVC valve that slides in and out for servicing purposes. I've pushed it in and out; still no house water. Its Saturday now; no Sears Kenmore repairman til Monday at soonest. Just thought I could tinker around with it myself and get it running. Good thing my wife's away this weekend!
  7. Gary Slusser
    Retired
    There is no other valve in a softener.
    You didn't answer my questions about what makes you think it is the softener and not a water shut off valve?
  8. Airborne16
    Jul 24, 2010
    Fort Hood, Texas
    Oh, sorry. I think its the softener because this same unexpected water shutoff occurred 2 weeks ago. We troubleshooted the water softener and the house water came back on within minutes. That does NOT necessarily mean there's a cause and effect. The city water company confirmed it was not a problem on their end of the meter. My water main at the meter splits into an inground sprinkler system (which is working fine right now....just tested it) and the main house intake which runs through the water softener. I don't know if I need a plumber or a Sears water softener technician. The in-house water worked fine a midnight last night. By 7 a.m. today not a drop through sinks or toilets. Hmmmmm.
  9. Airborne16
    Jul 24, 2010
    Fort Hood, Texas
    Oh, sorry. I think it might be the softener because the same thing happend 2 weeks ago. After troubleshooting the water softener the house water magically came on moments later. That does NOT necessarily mean cause and effect; maybe coincidental. The city water company confirmed the problem lies between the street-side meter and my house; not their problem. The meter splits my water into two usags: my yard sprinkler system (and its working fine even as we speak), and into my house via the water softener. I had house water usage at midnight last night and not a drop by 7 a.m. today. Not sure if I need a plumber or a Sears water softener technician. Thks for the comeback. Ron
  10. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is there a bypass on the unit that you could change from service to bypass?
    treated to untreated?
  11. Airborne16
    Jul 24, 2010
    Fort Hood, Texas
    Yes, and either way I've pushed it, it still hasn't triggered anything. No agua either way.
  12. jadnashua
    Either the bypass has broken or as Gary said, something else in the system (house, not necessarily the softener) is clogged. Gate valves when they fail can cause this, as can those with washers that fail.
  13. Akpsdvan
    Dec 29, 2009
    Alaska
    With it in bypass or in service there is no Water?
    If this is the case then find the valve just before the softener to make sure that it is open, I have seen a ball valve that is just before a system get turned to the off mod and no water into the house..
  14. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    Turn the main water valve off, depressurise and remove the bypass stem. Turn water on to make sure it's getting to the unit. Check for a bad oring on the plunger.
  15. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
  16. Airborne16
    Jul 24, 2010
    Fort Hood, Texas
    Team, the mystery is solved. I repiped my city water into my house BI-PASSING my water softener, and I STILL had no water flow...until I gently tapped my exposed PVC pipes. The tapping dislodged the blockage at the heart of my mystery. Calcium build-up, sediment, or something. My softener had been off for a couple of months due to a minor problem it was having, and that must've been enough hardwater to build up a blockage, the one 2 weeks ago and the one this weekend. I'm repiping my watersoftener back, exactly as it was, re-reading the user manual for the umpteenth time....and even then probably still having a Sears technician out this week to ensure it is operating correctly. I appreciate your contributions, Wally, Gary, Skip, Jim, and my friend in Alaska. My wife thinks I'm a blogg nerd but I was impressed by your knowlege and quick willingness to walk with me through this challenge. Ron...Airborne16
  17. Gary Slusser
    Retired
  18. Gary Slusser
    Retired
    You're welcome Ron, and thanks for your service.
  19. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    Go away, your entire purpose in life is to argue with people and start trouble. Get a life or get out
  20. Gary Slusser
    Retired
    Say WHAT!!
    Man you're getting emotional again.... Step away from the adult beverages earlier in the evening and then get more sleep and I promise you'll feel better.
  21. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    I'll back off the adult beverage when you back off the crack pipe
Similar Threads: Kenmore Ultra0Soft
Water Softener Forum, Questions and Answers Kenmore intellisoft 350 problem Jan 15, 2017
Water Softener Forum, Questions and Answers Kenmore control failure Feb 16, 2016
Water Softener Forum, Questions and Answers Sears Kenmore 370 at wits end :( Feb 14, 2016
Water Softener Forum, Questions and Answers Kenmore Ultrasoft 150 stuck in regen mode Jan 22, 2016
Water Softener Forum, Questions and Answers Kenmore water softener problem Jan 21, 2016
