Kenmore Ultra Soft 400 err 1 and major leaking
Discussion in 'Water Softener Forum, problems, installation and r' started by Jbutz23411, Feb 1, 2013.
  1. Jbutz23411
    Jbutz23411 New Member
    Feb 1, 2013
    Minnesota
    Hello. Today, I noticed the sound of a hose spraying in my basement. I investigated, and realized that the water softener says err 1 (It is the Kenmore Ultra Soft 400) and also, a hose connected to it is leaking uncontrollably. Turning off the water softener does nothing to stop it, except for it turns off the err 1 message. Now we are waterless as we turned off the water valve to avoid and flooding. What can I do?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    There should be a piston behind the valve that is the bypass if that was bought with the unit and installed at the same time, by pushing the piston end or turning a handle 90degrees that will bypass the system so that there is water in the house but untreated for now.
    As for the error 1, I would say by the book on the system that the most likely is the motor, either the motor has stopped working or that there is a short between the computer control and the micro switches and the motor or that the motor is just dead . The leak is most likely because the motor has not moved the cam to the service spot.
    As a note it is a sad state when others on this board will not answer a question on a sears system, it is almost like it is below their station to do so..
  4. Jbutz23411
    Feb 1, 2013
    Minnesota
    We kept the water shut off for awhile now, and we turned it back on so now we have no error message or leaking. Too good to be true, or problem solved?
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    I would do some trouble shooting on the unit.
    Check the bypass to make sure that it can be used should it be needed, either the piston type or the turn the handle .
    Push the start regen and then once the unit is in brine fill, wait and then pust the start regen again to the brine draw and repeat the steps after it has moved to the next part of the cycle to make sure that the motor is starting and stopping like it should be, and that when back to the service that there is no water going to the drain.
    It might have been an opps as in the one and only or there may still be a problem that needs to be fixed.
Similar Threads: Kenmore Ultra
Water Softener Forum, problems, installation and r Kenmore Ultrasoft 150 stuck in regen mode Jan 22, 2016
Water Softener Forum, problems, installation and r Guide to take head off of Kenmore Ultrasoft 275? Jul 28, 2014
Water Softener Forum, problems, installation and r Kenmore UltraSoft 480 - Regenerating/Drainin non-stop - - is it worth repairing? Apr 29, 2011
Water Softener Forum, problems, installation and r problem with kenmore ultra 800 water softener Mar 7, 2011
Water Softener Forum, problems, installation and r Kenmore Ultra0Soft 200 or 250 Shutting house water off. Jul 24, 2010
