Jet Pump Dry Run Protection – How to Judge Pump Quality?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Dean Erger, Feb 12, 2012.
  1. Dean Erger
    Dean Erger New Member
    Feb 9, 2012
    Pottsboro, Texas
    I’m looking for a new shallow well jet pump, probably 1 hp. Do most cast iron pumps have built in protection in case the water intake runs dry?
    I want to get a pump that will provide long reliable service. I’d appreciate recommendations for quality pump brands, or what to look for in a pump. I’ve read about some Gould, Red Jacket, Red Lion and Dayton pumps, but I don’t know enough to judge quality. I understand the specifications for gpm/well depth/psi, and maximum psi, and I assume that higher gpm/max psi may indicate a better pump, but the gpm/max psi of all the 1 hp cast iron pumps are fairly close. Pump prices, however, can vary significantly.
  2. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Goulds is pretty good.
    I can't comment on the run dry protection part of it, I don't deal with that a lot. I did run across something that would not let the pump run hot, but I'll have to look it up.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Goulds; Sta-Rite; Berkley all build quality pumps. Install a low pressure cut-off pressure switch or even better a Digital Pressure Switch
    EPS15/9 from http://www.cyclestopvalves.com/index2.html. Either will shut the pump down when it looses prime.
  5. Dean Erger
    Feb 9, 2012
    Pottsboro, Texas
    I installed an EPS15/9. Looks very well made. Heavy duty. Works fine.
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The EPS15/99 also has low pressure cut off to protect the pump from a dry run condition.
Similar Threads: Pump Protection
Pumps and Tanks Well Forum & Blog. Water is life. Pump Protection Jun 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pumpstop pump protection switch Nov 6, 2013
Pumps and Tanks Well Forum & Blog. Water is life. pump protection Jul 19, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Protection on low/no water Oct 4, 2010
Pumps and Tanks Well Forum & Blog. Water is life. 20/40 or 30/50??? pump protection HELP Aug 10, 2009
