Jamie's Toto Drake Install Instructions
Discussion in 'Toilet Forum discussions' started by DJ2, Oct 23, 2005.
  1. DJ2
    DJ2 Guest
    Jamie's install instructions differ on a couple of points with the instructions that came with my Toto Drake. The instructions in the box say to put the wax ring on toilet first, not on the floor flange. They also say to install the tank after setting the toilet, not before.
    I did it per the enclosed instructions and it worked great. I used all of Jamie's other tips too. The combination of info was very helpful.
    The toilet is easier to handle without the tank on it.
    Having the wax ring already on the toilet worked well too. It allowed me to use the non sticky plastic horn of the wax ring to bump around within the drain hole when I was placing the toilet. It was helpful to use this tactile feedback to verify I was centered over the hole. If I tried this with the ring already in place over the hole my bumping around would be hampered by the stickiness of the wax.
    Have you guys done these things both ways and found Jamie's way to be preferable?
Similar Threads: Jamie's Toto
Toilet Forum discussions 2 Questions Re: Jamie's Toto toilet install Jun 7, 2013
Toilet Forum discussions Jamie's Drake installation Guide - comments Jan 23, 2006
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Saturday at 9:53 AM
Toilet Forum discussions Toto toilet seat hinge cover Friday at 4:53 PM
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
