ScottAllen
There is a youtube video link at the bottom of this post showing the possible water hammer in my basement near the main water supply.
Listen to the sound after the water shuts off.
I still dont know if this is water hammer OR the contraction & expansion of pipes.
Regulator has been changed. Water pressure is around 50 to 60 Psi.
I have also insulated the pipes.
If this is water hammer, does installing this arrestor SharkBite 3/4 Inch Residential Water Hammer Arrestor, Push to Connect Brass Plumbing Fittings, PEX Pipe, Copper, CPVC, PE-RT, HDPE, 22632LF https://a.co/d/5hJOeRV
At the main supply help?
Should i install it below the regulator or above?
Any help is appreciated.
If this ignored it can be a problem in future right?
