Gritres
This question pertains to centrifugal pumps w/ a shallow well. When trying to get as much GPM as possible it's common to connect multiple wells to a single pump to limit the effects of drawdown and get more effective surface area from more well points. This effectively increases the water column size and weight that is being suspended by the check valve (assuming single check valve at top near pump, dont wish to discuss foot valves.). Assuming the check valve is beefy enough to handle all that, does this increase of suspended water volume cause extra strain on the pump or is it one of those cases where bigger diameter always equals less resistance?
I'm trying to decide between sinking three 5 foot 1.25" diameter points or or two 5 foot 2". Both solutions have similar screen surface area but two 2" pipes will hold a lot more water volume and if that is a detriment to the pump then the smaller pipes would be ideal. The pump has a 2 inch inlet.
