Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
Discussion in 'Shower & Bathtub Forum & Blog' started by paule123, Jun 12, 2005.
  1. paule123
    paule123 New Member
    Mar 9, 2005
    The bathroom is completely gutted. We're getting ready to put the PVC drain pipe in for the shower and it needs to go through 2 or 3 joists to join the main stack. I notice all the shower drains are designed for 2" pipe. To keep the joist holes as small as possible is it ok to transition from say a 2" P-trap to 1 1/2" pipe, or am I asking for trouble (slow drains) later on?
    Also -- this is a 2nd floor bathroom and we don't want to open up the ceiling below for P-trap access -- I assume I need a one-piece P-trap (without the swiveling adjustable thingy) and need to be right on the money for exact center of the shower before we glue it together, before we put the subfloor down?
    Thanks.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    2 inch
    it would be wise on the second floor just to do it right and not
    fool around cutting corners....you might pay for it later...
    1 1/2 will barely work on a shower situatioin
    although I have seen it done that way many times
    in many older homes that was what was used.....
    but if you have got the walls open , its not that much more trouble to
    drill 2 inch holes and not worry about the shower drain getting overwhelmed
    someday in the future.....
    yes, you really should install a solid pvc trap on the second floor
    Wether you are capable of hitting the measurement perfect on
    that trap is the big question
    if you measure it perfect to center and use the type of PVC shower
    drain with the rubber neopreme gasket in it you can glue everything
    together but the stand pipe comming up through the floor
    of course you can try this without useing the glue to make sure you got it right first.... then mark all the fittings with a majic marker so you stay on the money... and do the final run with glue....
    you can set the base in place then measure the stand pipe and
    glue it in through the drain hole once the base is in place and you are sure about everything being perfect....if you so wish , that makes things easy
    then install that neopreme gasket and tighten it down....
    good luck , have fun
Similar Threads: drain pipe
Shower & Bathtub Forum & Blog Tub drain trip lever stuck in pipe Dec 6, 2016
Shower & Bathtub Forum & Blog What parts would I need to replace this sink drain pipe? Mar 10, 2014
Shower & Bathtub Forum & Blog Considering attaching PVC pipe to cast iron drain with epoxy! Nov 7, 2013
Shower & Bathtub Forum & Blog advice on best way to get drain pipe to fit in new shower pan Jun 6, 2013
Shower & Bathtub Forum & Blog Connecting Shower Drain to 4" Iron Pipe Apr 18, 2013
