Irrigation Solinoid Zone Valve "Hammering"
Discussion in 'Irrigation / Sprinkler Forum' started by GeorgeM, Oct 16, 2008.
  1. GeorgeM
    GeorgeM New Member
    Oct 16, 2008
    Hi Terry-
    My Irrigation System (6 Zones with Hardie RD-600 Controller) are innitially "hammering across all 6 zones" for about 5-8 seconds when either in auto or manual mode. The system is about 10-12 years old and I did'nt initially have this problem. The street water pressure is about 55 - 65psi. I believe the valves are also "Hardie". I will check to see model nos. Possibly..... Does the diaphrams / solinoids need replacement to correct this chatter???? The piping in the basement really chatters at startup across all zones. I appreciate your advise!
    Thanx..... Geo
  2. hj
    chatter
    IF it happens with all the valves then the problem is probably in the piping to them, or more specifically, the antisiphon valve that the water should flow through first.
Similar Threads: Irrigation Solinoid
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum Irrigation Winterizing help Oct 27, 2016
Irrigation / Sprinkler Forum Reviving Old Irrigation System Oct 9, 2016
Irrigation / Sprinkler Forum What's best size of Irrigation pipe Aug 24, 2016
Irrigation / Sprinkler Forum Agriculture Irrigation Pipe Aug 22, 2016
