Interior Plumbing on geothermal heat pump
Discussion in 'HVAC Heating & Cooling' started by clayfish, May 25, 2008.
  1. clayfish
    clayfish New Member
    May 25, 2008
    I have two geothermal heat pumps in my house, one for the first floor and one for the second. The water flow through the two heat pumps is in series. The water enters the first heat pump and moves to the second pump when it exits the first. When the water exits the second pump it splits and goes in parallel to two control valves controlled by each heat pump. That way if either pump is running the water flows through both. I have been advised to change to parallel so that each heat pump controls its own water flow independently. Does any one know if this is the best way. I have all of the plumbing parts to make the change tomorrow but I dont want to make a mistake.:)
  2. jadnashua
    Systems are more efficient if the temperature difference is high. By running it through one system then the other in series, the second one is getting warmed up water, and therefore working harder and less efficiently.
Similar Threads: Interior Plumbing
HVAC Heating & Cooling Interior wall is now an exterior one Nov 10, 2008
HVAC Heating & Cooling GV90+ Boiler Plumbing Problems Oct 12, 2014
HVAC Heating & Cooling correct plumbing for radiant connection to heat loop Jan 13, 2012
HVAC Heating & Cooling Noland Plumbing drops Rheem Jul 11, 2009
HVAC Heating & Cooling RePlumbing old hot water system for efficiency Aug 17, 2008
