Installing new Schedule 40 Bath Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by mi21stinf, Apr 8, 2008.
  1. mi21stinf
    mi21stinf New Member
    Apr 8, 2008
    Michigan
    I'm installing a new Schedule 40 Bath Drain with no instructions on a new Sterling 7112 tub.
    According to the supplied materials I have the parts installed in the following order (bottom up):
    1. plastic drain
    2. rubber gasket
    3. Tub
    4. Strainer
    The instructions I been able to find are for cast iron tubs and show using Plumbers Putty between the strainer and tub.
    Other instructions state to never use plumbers putty on a plastic/fiberglass tub. But, don't tell what if anything to use.
    Can anyone provide the recommended installation technique?
    thanks,
    BJR
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You can use Silicone RTV kitchen and bath caulk or, There is a new putty on the block that can be used...
    [​IMG]
    Sta Put® Ultra™
    A unique, professional grade non staining plumber’s putty that is safe for most types of plumbing fixtures and surfaces. Unlike all other plumber’s putty Sta Put Ultra is oil-free and can be used without pre-treatment. This includes natural, porous surfaces such as stone, marble, granite, plastics, rubber, and fiberglass, as well as grout and on manufactured sinks, shower bases, countertops, and other surfaces. Molds easily, remains permanently soft, malleable, and flexible. Sta Put Ultra does not melt, rot, crumble, dry out, or shrink. Easy to clean-up. Does not leave a greasy residue on hands or surfaces. Meets or exceeds Federal Specification A-A-3110 (formerly TT-P-1536A).
    U.S. and foreign patents pending.
  4. mi21stinf
    Apr 8, 2008
    Michigan
    Thanks
    Thanks for the quick reply.
    BJR
Similar Threads: Installing Schedule
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
Shower & Bathtub Forum & Blog Installing new tub drain around a lead drum trap May 8, 2016
