Installing attic ladder - joists are overlapping
Discussion in 'Remodel Forum & Blog' started by smithx3, Jul 14, 2008.
  1. smithx3
    smithx3 New Member
    Sep 16, 2007
    We are installing an attic ladder above our garage. We need a rough opening of 22 1/2", but the ceiling joists are overlapping each other (side by side), so there is only 21" between the joists. Can we cut back part of one of the overlapping joist and add a sister joist to the other side? I am working on uploading a photo or sketch to more clearly illustrate, but if anyone has ideas in the meantime, that would be great. Thanks!
  2. jimbo
    jimbo Plumber
    You will need to head off the joist that you cut out.
  4. hj
    joists
    Are they just overlapping because it is a tail that projects past a bearing wall? If so, then the the piece may be redundant and can be cut off.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Are all the joists like this, or did you just happen to find the one sistered-up pair in the ceiling?
  6. smithx3
    smithx3 New Member
    Sep 16, 2007
    Thanks for all the replies.
    All of the joists above the garage are overlapping exactly the same way. They are all 2x4 joists; the overlap is about 3 feet. Unfortunately, due to the slope of the roof, the only place that the ladder can go is right where the joists are overlapping.
    I've uploaded a diagram (just too darn hot to go up there and take a picture); I re-sized it so I could do the upload, sorry it is a little bit small.
    Thanks again!
  7. AZ Contractor
    AZ Contractor In the Trades
    Apr 21, 2007
    Phoenix, AZ
    Is there a wall or header underneath where they are overlapping?
    Are they collar ties as well as ceilnig joists?
    Hard to see your picture, Can you cut out the white area more and enlarge the detail?
    Take a picture from below and draw on it where you want the opening then do the same from up above if you want accurate replies.
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Are these conventional joists or part of a truss system? What is the span? The reason I ask is -- if you're putting a stair in the ceiling it's because you want to get up there for some reason. If that reason is to put in a floor and store all your stuff up there, you may have a load problem with 2x4 "joists". Right now they may only be serving to hold the walls in from spreading from the rafter load, which is fine, and your proposed sister should do the job, but they may not support any floor loading above.
    http://www.youtube.com/watch?v=JLoge6QzcGY
  9. hj
    joist
    You don't show or tell why they are overlapping. Normally they would only overlap if there were a supporting wall somewhere under the overlap, unless they are acting as a tensioner between the outside walls.
  10. Livin4Real
    Livin4Real New Member
    Sep 7, 2007
    Flight Operations and DIY'er
    Indianapolis, IN
    Hopefully smithx3 means "i-joist" instead of 2x4".
Similar Threads: Installing attic
Remodel Forum & Blog Identifying issues with installing freestanding tub in basement Jul 11, 2016
Remodel Forum & Blog Installing DOMJSO double-sink without countertop on a single 36" cabinet Feb 29, 2016
Remodel Forum & Blog Installing Kohler K-1160G Air Bubble tub Feb 14, 2016
Remodel Forum & Blog Installing Dishwasher Aug 18, 2014
Remodel Forum & Blog Installing a single oven below the counter. Anyone done this? What size base cabinet? Jun 4, 2014
