Install Upstairs Radiators, do I need valves?
Discussion in 'HVAC Heating & Cooling' started by farmer_dave, Dec 29, 2009.
  1. farmer_dave
    farmer_dave Farmer in PA
    Nov 26, 2009
    PA
    I am a diy guy that has an old farm house currently with no upstairs heat (iron radiators were cast off by the last owner). To get heat to the 4 bedrooms and 1 bath upstairs I have been able to run 2 loops of 3/4 pex (4 pipes) to the upstairs bathroom where I will be able to make two separate loops to the bedrooms and bath. Being on a tight budget, I would like to install slantfin along the windows, but wonder about one bedroom overheating and one being too cold. Has anyone used thermostatic valves like the ones sold by http://www.mysoninc.com/client_imag...es/radiator_thermostaticvalves_listprices.pdf
    My next step is to contact myson but thought I would ask here to get an unbiased opinion. Thanks for any info on thermostatic radiator valves.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Just put the baseboard in. You can control the output with the dampers on the baseboard.
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I have not used that exact brand but I have used a very similar model and they worked quite well! I would definitely recommend them!
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Great for balancing your system. I recommend them for your bedrooms. Bathroom would be optional (personal note: I would put them in the bathroom too)
Similar Threads: Install Upstairs
HVAC Heating & Cooling Ducted and ductless mini split system installation cost - reasonable? Jan 17, 2017
HVAC Heating & Cooling I absolutely need to use a common wire to install my Nest...which is the common? Dec 7, 2016
HVAC Heating & Cooling Goodman cased evaporator installation Oct 21, 2016
HVAC Heating & Cooling Condensate + attic install + gravity = bad Sep 11, 2016
HVAC Heating & Cooling American Standard Air Handler Install Jul 24, 2016
