Insinkerator SST hot water tank problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by okiemon, May 13, 2013.
  1. okiemon
    okiemon New Member
    May 13, 2013
    Oklahoma
    I think I have a faulty tank, but thought I'd post a note here to make sure. My daughter's Insinkerator hot water dispenser is not dispensing any water. I inspected the lines, and there aren't any kinks or leaks. I also removed the tank, drained it and flushed it, and then drained it again. When I hooked it back up, and turned the dispenser handle, I could hear the water running into the tank (in her system, the incoming line goes into the tank through the dispenser valve rather than directly). The tank is also heating when plugged in. But still, no water comes out. Time to replace the tank?
Similar Threads: Insinkerator water
Plumbing Forum, Professional & DIY Advice Insinkerator hot water dispenser tank with non insinkerator faucet? May 30, 2015
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator Instant Hot, Contour Installation Tips, plumbinghacks Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator Evolution Disposal Tail Pipe Too Short Mar 20, 2016
Plumbing Forum, Professional & DIY Advice Installing new badger insinkerator Mar 2, 2016
