Inside 32" x 32" NEO style Showers
Discussion in 'Shower & Bathtub Forum & Blog' started by Jima, Jan 6, 2006.
  1. Jima
    Jima New Member
    Jan 6, 2006
    On an earlier reply someone stated a NEO style 32" x 32" shower stall would not be large enough to use. Does anyone know what the interior size from the back corner edge is to the front door?? Thank you.
  2. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    if thats all you can fit, then a 3/4 bath is better than a 1/2. snuck the same pan in my 1/2 bath. used it every day until i needed to wash my feet! :eek: then used the bath upstairs. lol
  4. Jima
    Jima New Member
    Jan 6, 2006
    Thanks for the reply, but I was interested in the inside measurements of the shower floor of a 32" x 32" NEO style (5 sided shower stall) floor. Specifically from the back corner where the walls come together, to the front door.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    thats pretty small
    a 32x 32 neo style base just have to be extremely small
    be warned
  6. hj
    base
    You would have to make your own base, because the smallest premade ones I know of are either 36"x36" or 39"x39". A 32"'x32" one would very small, almost to the point where it would be difficult to bend over to pick up a dropped bar of soar. The thing that determines the inside dimension from the front to the corner is the size of the door opening, since that is what alters the side dimensions, and thus the inside space.
Similar Threads: Inside style
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Shower door rail has openings INSIDE the shower? Ruining caulking. Feb 20, 2016
Shower & Bathtub Forum & Blog Question on plunger/stopper inside a tub waste overflow drain Dec 19, 2015
Shower & Bathtub Forum & Blog Diverter leaking from inside tube. please help identify/locate part Sep 12, 2015
Shower & Bathtub Forum & Blog Installing a fan inside your steam shower: Good idea or bad Jan 27, 2015
