Rust particles have been clogging up the very expensive valves in my Herbeau tub filler. I am investigating ways to prevent this, aside from replacing all the pipes and the water heater (which is only 3-4 years old). I live in a townhouse, share walls with neighbors, and seek a minimal damage control solution.
As you can see in the photo below, I have a little door that provides access to the shutoff valves and supply lines, which are flexible crimped-style PEX. Sitting outside the door is my first try at putting together a solution - one branch of the Y has a screen and a cleanout plug. The ends of the assembly are shark-bite for ease of connection - I do not have a PEX crimping tool, nor would there be space to crimp even if I did. The whole thing is quite large for the space available, and I'm seeking more compact alternatives. I'd like to find something like what the Symmons LL-71B inline check valve with screen provides for standard 3/8" supply lines outside the walls, except for inside the wall and with PEX.
Aside from safety, size is the most important issue. I'd rather keep it as simple as possible and not have to open the wall up any more. I am considering shark bite connectors for convenience but am interested in people's take on the safety of using them in retrofit applications like this with existing flexible tubing.
Ideas? Thanks!
Ideas? Thanks!
