Ideas on sprinkler heads
Discussion in 'Irrigation / Sprinkler Forum' started by duke69111, Jul 20, 2010.
  1. duke69111
    duke69111 New Member
    Jun 27, 2009
    Real Estate
    Wichita, Ks
    Hi All,
    Two months ago I laid sod around my back patio, but my current configuration does not quite get complete coverage. I have attached a picture of the layout and the way the heads are positioned and set to spray. The large one on the left is a 180, and the remaining three all spray in two ways.
    Does anybody know where I can get the heads that spray two ways as mine don't seam to spray to the sides quite far enough or a different type of head that would work in this situation?
    Thanks for any help.
  2. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    The 2-way heads available that I am aware of from Rainbird are the 9CST (9' x 18') and 15CST (4' x 30')
    15 Strip Series
    Width Flow
    Model PSI X Length GPM
    15LCS
    Left-Corner Strip
    15 3' x 11' 0.35
    20 3'' x 12' 0.40
    35 4' x 14' 0.45
    40 4' x 15' 0.49
    15RCS
    Right-Corner Strip
    25 3' x 11' 0.35
    30 3'' x 12' 0.40
    35 4' x 14' 0.45
    40 4' x 15' 0.49
    15SST
    Side Strip
    25 4' x 26' 0.89
    30 4' x 28' 1.00
    35 4' x 28' 1.11
    40 4' x 30' 1.21
    15EST
    End Strip
    25 4' x 13' 0.45
    30 4'' x 14' 0.50
    35 4' x 14' 0.56
    40 4' x 15' 0.61
    15CST
    Center Strip
    25 4' x 26 0.89
    30 4' x 28' 1.00
    35 4' x 28' 1.11
    40 4' x 30' 1.21
    9SST
    Side Strip
    25 9' x 15' 1.34
    30 9' x 16' 1.47
    35 9' x 18' 1.60
    40 9' x 18' 1.73
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Strip heads have never worked well for me. You are better off to run 90's and 1/2's along both sides of the narrow area, spraying towards the middle. Use 5' heads and you should be ok
  5. Fireguy97
    Fireguy97 Irrigation Contractor
    Mar 21, 2010
    Irrigation Contractor / Certified Backflow Assembl
    Kamloops, in Beautiful British Col
    Change your configuration.
    You will not be able to get heads to properly cover your areas unless you move your existing heads and add additional heads. You also haven't given us any dimensions.
    There is no possible way to get proper head-to-head coverage with four spray heads, it doesn't matter what nozzles you look for, unless you flood your entire yard once a week. You must have brown spots all over the place.
    Mick
  6. duke69111
    Jun 27, 2009
    Real Estate
    Wichita, Ks
    I will add dimensions tonight, forgot about doing that last night.
  7. duke69111
    Jun 27, 2009
    Real Estate
    Wichita, Ks
    Dimensions
    Here are the Dimensions.
Similar Threads: Ideas sprinkler
Irrigation / Sprinkler Forum Ideas for pump Sep 15, 2010
Irrigation / Sprinkler Forum Sprinklers worked, now not at all. For no apparent reason. Mar 11, 2017
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
Irrigation / Sprinkler Forum Sprinkler head problem Sep 18, 2016
