I need help with hydronic heating installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SAVROOM, Oct 14, 2013.
  1. SAVROOM
    SAVROOM New Member
    Oct 14, 2013
    Mountain View, CA
    I don't see a hydronic heating-specific forum here....am I overlooking it? I'm in the process of designing and installing a hydronic heating system in my home and have a number of technical questions.
    Could someone point me to a forum dedicated to helping non-plumbing professionals with hydronic heating systems?
    Thanks
    Edit: adding a zone diagram....does this make sense to anyone that understands hydronic design?....appreciate any comments. I'm using Runtal radiators, a mix of wall and vertical style radiators.
  2. hj
    Most of us would probably use a single pipe MonoFlo system, but the two pipes system MAY work better when most of the valves are closed. It is just more expensive to do it that way.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
  5. SAVROOM
    SAVROOM New Member
    Oct 14, 2013
    Mountain View, CA
    I was told by the Runtal rep that in a mono-flo system the water is cooler by the time it get's to the last radiator...which makes sense to me since each succeeding radiator is draining heat from the water. He said the parallel piping will ensure a consistently heated water supply to all radiators simultaneously....and looking at the design I believe he is correct.
    He said that mono-flo systems are preferred by some installers because they're cheaper and easier to install but not necessarily best for the customer.
    Also, I don't understand the statement "two pipes system MAY work better when most of the valves are closed". Please clarify why you believe this to be true....to me that makes no sense.
  6. SAVROOM
    SAVROOM New Member
    Oct 14, 2013
    Mountain View, CA
    Mods, please move this thread to the HVAC forum...thanks.
  7. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Your diagram is the preferred method for piping radiators, convectors and flat panel radiators. It gives the least temperature variation and the least pressure drop across the system. It may or may not be slightly more expensive due to the extra piping needed but, monoflow tee's are pretty pricey and I suspect that the cost difference is minimal. I have a similar arrangement in my own home using 5/8" heat pex so the cost of the piping is negligable. If you are hooking everything up to a Mod-Con boiler you will need either a differential bypass or a tempering valve on the return side to keep the return temperatures in the condensing range. If its a standard, non-condensing boiler you will need to bleed some feed water back into the return to keep it from condensing.
Similar Threads: need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
