Hi -
on a remodel job I had to drain the water system so it wouldn't freeze up on me during construction. Now I put it back into service I have one zone that simply won't circulate properly.
I have flushed the loop several times, vented the baseboards, etc ... all the usual stuff. I even completely drained the boiler and started from scratch. I even replaced the circ pump of that zone. When I drain that zone hot water runs through it just fine just from the system pressure. When I go back to the circ pump after 10 min or so it seems there is no water circulating and the pipes get cold.
Any suggestions would be appreciated. Thanks
