Hydronic baseboard bleeding problem
Discussion in 'HVAC Heating & Cooling' started by pbaxter, Oct 6, 2009.
  1. pbaxter
    pbaxter New Member
    Mar 26, 2009
    Note- I also posted this in the Boiler forum since the topic seemed to fit both areas. Apologies if this violates cross-posting rules.
    Have a 2-story house with one-zone hydronic baseboard heating (upper and lower floors are piped separately, but only one thermostat). This is an old house with heavy cast-iron baseboard radiators.
    All rooms get heat EXCEPT one room on the upper floor. Naturally I expected to get air when I opened that room's radiator's bleeder valve. Instead I got lots of cold water and no air coming out (circulating pump was running).
    What now? Clearly water is getting into this radiator -else I wouldn't get (cold) water out of the bleeder. After bleeding, the inlet side wasn't even a little bit warm.
    Could the outlet side (downstream of the bleeder) be clogged?
    Could the inlet valve be faulty (only letting water flow when there's a big pressure differential)?
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Are you sure the valve to that radiator is open? I have seen the handles become striped. Check to be sure the stem is turning with the handle.
    John
  4. pbaxter
    pbaxter New Member
    Mar 26, 2009
    Pretty sure. I opened it so far that the stem shot out of the valve and water spurted out. Also, water came out the bleed valve.
  5. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    Replace the valve. If the stem came out it is no longer working. The water you are getting out of the vent is coming from the return side of the baseboard. Both ends of the baseboard must be open to promote circulation.
    John
  6. pbaxter
    pbaxter New Member
    Mar 26, 2009
    Good point. I'll look into taht.
    Thanks!:)
Similar Threads: Hydronic baseboard
HVAC Heating & Cooling Electric Hydronic Baseboard, Or Regular Convectors? May 1, 2016
HVAC Heating & Cooling thermal fluid hydronic baseboards Mar 15, 2009
HVAC Heating & Cooling Replacing hydronic baseboard radiators Feb 25, 2008
HVAC Heating & Cooling electric baseboard or hydronic baseboard Dec 27, 2007
HVAC Heating & Cooling hydronic baseboard specs Aug 14, 2007
