Hybrid heatpump air to water options
Morrelli
California
Hello all,
I have posted here a few times and still exploring options. I have a 30 year old LP American water heater supplying DHW and a loop to two separate air handlers for heat, upper and lower floors. Is it possible to replace the HWH with an air-water heat pump for heating needs as well as a/c and use a nacien or other tankless for DHW? Trying to eliminate as much LP use as possible and utilize as much solar and batt storage as possible. Outside of that a.combi boiler seems a potential.alternative but does.bot decrease my LP consumption as dramatically. Thanks in advance.
Fitter30
Peace valley missouri
There are several manufacturers what your looking for but none will meet your needs for heating hot water max is around 110 to 120°.
Don't know if anyone is making a low temp air handler like the baseboards.
Fitter30
Need to look at btu's needed for heat. Thicker or more fins per inch will take more hp for a certain amount cfm. Cfm is more critical for ac than heat.
John Gayewski
Iowa
Air to water heat pumps aren't usually capable of meeting heating needs. Generally the other way around. You might want to explore geothermal loops. They can do some cool stuff with those.
Morrelli
California
I wish I could. As this is an existing system with its challenges I'm pretty much stuck as is. I can pull the HWH and replace with a combi unit, which will update things a bit, and add some reliability but won't help me much with reducing LP use, (i think). Just trying to figure a way to rely more on electric as I am a victim of being a california resident with lots of solar advantage but rising LP prices.
Fitter30
Combi heaters are so so efficient because of condensing. Low return water temp under 130° lower the better above 87%. Might want to look into solar dhw
wwhitney
Berkeley, CA
Take a look at chiltrix.com. They support using a single unit to provide DHW and space heating/cooling.
Cheers, Wayne
Morrelli
California
I have looked into solar DHW but the recovery times are pretty steep. Sanden/Sandco does pretty well, so that's a potential option.
Morrelli
California
Cheers, Wayne
Thanks Wayne. Interesting site. Any personal experience with their products? I don't believe I've ever heard if them before now. I'm not in the trade as you may have already picked up on but I'm a fanatical researcher of sorts.
wwhitney
Berkeley, CA
I have installed one, but just for space heating/cooling, not DHW. It was a bit of a learning experience but seems to be working OK.
Cheers, Wayne
