HVAC split AC question
Discussion in 'HVAC Heating & Cooling' started by lawrencetj, Apr 6, 2008.
  1. lawrencetj
    lawrencetj New Member
    Apr 4, 2008
    Greetings Everyone,
    I've got a double wide mobile home (1300 sqft) with an addition (350 sqft). The addition is not heated or cooled at all.
    Is it possible to get a larger outside condensing unit to run two indoor air handling units?
    Thanks,
    Timothy
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Yes, but sizing and balancing that may cost more than it is worth. For starters, assuming your existing air handler is 10 SEER, it would have to be replaced to match a new 13 SEER condenser. A much better idea would be a through the wall heat pump unit, even a hotel size PTAC unit; or one of the new mini-split systems. fujitsu, mitsubushi, and LG all make very good units.
  4. Russell Guillette
    Russell Guillette New Member
    Mar 14, 2008
    Building Mgr.
    You need to match the tonage of the air handler with the tonage of the condenser unit.
  5. lawrencetj
    Apr 4, 2008
    Ok, so after some extensive research, I at least know what stuff is. I have another question.
    I live in southern Louisiana. We have hot humid summers and mild winters. Would a heat pump be efficient for heating in my climate?
    Thanks,
    Timothy
  6. jimbo
    jimbo Plumber
    San Diego, CA
    Heat pumps are appropriate in climates where the winter season temps seldom go below 35 or so. The knock on heat pumps is that the air handler blows luke warm air, so it does not have the same warm cuddly feeling as radiators, or fuel-heated forced air. But the price is right!
Similar Threads: HVAC split
HVAC Heating & Cooling Balancing my HVAC system? Dec 12, 2016
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling I have a couple of HVAC questions Nov 7, 2016
HVAC Heating & Cooling HVAC Ducts in Attic Oct 6, 2016
HVAC Heating & Cooling HVAC Question Aug 10, 2016
