How to tell if a pipe is pressurized
Discussion in 'Irrigation / Sprinkler Forum' started by ErrayHota, Sep 23, 2011.
  1. ErrayHota
    ErrayHota New Member
    Sep 23, 2011
    UT
    I need to tap into a line that is going to a hose bib, so that I can add another hose bib in another location. The problem is that in the place where I'm gonna dig to get to the pipe, there are actually 3 or 4 pipes running together in that trench. Only one is pressurized, that is, going to the existing hose bib. The others are different sprinkler zones. Is there a way to determine which pipe to tap into? Or do I have to just start cutting until I find the right one?
    Thanks.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Assuming the water is cold, run the water out the hose bib and feel for which pipe is the coldest.
  4. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    you may also feel the vibration of the water through the pipe.
Similar Threads: tell pipe
Irrigation / Sprinkler Forum Sprinkler system bid...Can you tell me if it looks okay? Jul 10, 2014
Irrigation / Sprinkler Forum Which part do I need to connect new pipe to existing pipe? Jan 29, 2017
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum Use of Pvc Drainage Pipe Sep 2, 2016
Irrigation / Sprinkler Forum What's best size of Irrigation pipe Aug 24, 2016
