How to seal Delta shower valve ?
Discussion in 'Shower & Bathtub Forum & Blog' started by CharlieM, Jul 8, 2006.
  1. CharlieM
    CharlieM New Member
    Jul 1, 2006
    Iowa
    I just installed a Delta single-handle shower valve in an acrylic shower enclosure and I'm wondering how to seal up around the cover plate.
    No matter how I adjust the plate, there is a small gap in the seal on the plate around the valve handle area. There is a foam ring on the cover plate, but it seems far from adequate to actually seal around the valve. Water bouncing off a body will almost certainly find it's way past this. Is this an area best left to silicone caulk ?
    Also, should I run a bead of caulk around the outer rim of the cover plate ?
    Thanks,
    Charlie
  2. jimbo
    jimbo Plumber
    The provided foam rings are generally adequate. You can caulk if you wish, but try to achieve the smallest possible visible bead, because caulk inevitably becomes a maintenance issue.
  4. norcal1
    norcal1 Plumber/Owner
    Jan 24, 2005
    I've never had any call back issues with those foam gasket backed cover plates...I don't use any caulk.
Similar Threads: seal Delta
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Help identify mystery tub drain shoe sealant/gasket Jul 29, 2016
Shower & Bathtub Forum & Blog Fixing poor tub surround - how to seal vertical gap? Nov 24, 2015
Shower & Bathtub Forum & Blog Sealing new faucet Sep 3, 2015
