How to remove vinyl underlayment (paper stuff) on concrete bathroom floor?
Discussion in 'Remodel Forum & Blog' started by qkrinkle, Aug 16, 2008.
  1. qkrinkle
    qkrinkle New Member
    Jun 23, 2006
    We've removed the old viny. and there is an old paper underlayment that we've tried to scrape it up, but it's taking forever.
    Any ideas? We used a underlayment liquid remover that mixes with water but it's super slow going....
  2. jimbo
    jimbo Plumber
    San Diego, CA
    You have the two methods! Scraping and solvents. Be very careful with solvents....flammability and breathability come to mind.
    If it is on concrete, you can rent a floor grinder, but really before using that the residue should be lab tested to see if it has asbestos.
  4. jadnashua
    It will also matter what you intend to install after you get that up. Thinset doesn't like solvents and can be a bond breaker if you are intending tile. In fact, many glue-down things won't like solvents.
    A big razor scraper on a long pole works, but it is not easy. Get lots of extra blades so you have a realtively sharp one.
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Don't forget heat.
    The proper amount of heat can soften the adhesive. It is better to use it with the vinyl still intact but It'll still work.
    Make sure you use the scraper with the replacable blades (like long razor knife blades).
Similar Threads: remove vinyl
Remodel Forum & Blog Vinyl siding---should I remove the old shingles first? Apr 6, 2009
Remodel Forum & Blog Removed galvanized service line and pull through poly? Apr 1, 2015
Remodel Forum & Blog Remove foil from one side? Dec 11, 2013
Remodel Forum & Blog How much of the old fireplace can I remove? Aug 19, 2013
Remodel Forum & Blog Recessed Wood Framed Mirror -- how to remove caulk without damage? Oct 23, 2012
