How to Remove a Broken Tub Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by riddle112880, Nov 14, 2005.
  1. riddle112880
    riddle112880 New Member
    Nov 14, 2005
    While attempting to remove an old tub drain with a dumbbell wrench, the drain spindle broke. Does anyone know how to remove a tub drain with no spindle inside of it? Any assistance or advice would be greatly appreciated!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    I do this all the time. You use a Sawsall and 24 tooth blade very carefully. You cut the drain flange in 2-3 places through where the threads are but not cut the tub and as much of the flange as possible. Then pry up with a screwdriver until you can grab it with a pair of channel locks then back and fourth until it brakes. then there will be enough play to get the rest out. You have to be very carefull.
    I'll bet I have done this 50-60 times on old tubs. I have only scratched 1 tub and that was very minor. I always get home owners permission first. I explane that I have no other way to do it and if I scratch anything I'm not responsible. If anyone knows a better way I'm all ears.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Ridgid model 342 internal pipe wrench
  5. riddle112880
    Nov 14, 2005
    Job completed...Thanks!
    I used a reciprocating saw as suggested and cut a 1/2 inch notch in the drain. After that I tapped the remaining threaded sides with a hammer and chisel. The drain loosened and I was able to unscrew it. Thanks for the advice.
Similar Threads: Remove Broken
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Can't remove a broken nut Jul 8, 2009
Shower & Bathtub Forum & Blog Broken pipe at threads-how do I remove it? Jul 12, 2006
Shower & Bathtub Forum & Blog Diverter stem broken - unable to remove Jun 20, 2005
Shower & Bathtub Forum & Blog How to remove cartridge? Yesterday at 10:30 PM
