How to reinsert tub drain toggle assembly?
Discussion in 'Shower & Bathtub Forum & Blog' started by charlikin, Feb 22, 2009.
  1. charlikin
    charlikin New Member
    Oct 15, 2008
    Hi all - hoping this is an easy question! My brand new (2 months old) tub drain was running slowly, so I used a Zip-It drain cleaner (the long plastic thing with hooks) to pull a huge wad of hair and dried-up conditioner out of it. Drain runs fine now.
    Unfortunately, when the Zip-It pulled up the clog, the hair was so clogged around the drain toggle assembly that it pulled that up as well! I tried inserting the assembly back into the drain, but it doesn't make it quite all the way, and I'm not sure what to do next. Also suspect the assembly is supposed to connect somehow to the turn control on the overflow, but I'm not sure how.
    This is a Kohler K-7161 drain, btw. And I am emphatically not a plumber. Is this something I can fix myself, or do I need to hire a professional???
    Appreciate any help and advice!!! (Especially if I *can* fix it myself - my bathroom remodel was expensive enough!)
    TIA!
  2. charlikin
    Oct 15, 2008
    Never mind! I think I figured it out - I had to turn the control so the stopper would be in the down position, and then the assembly fit the rest of the way through.
    Whew!
    Thanks anyway. (sheepish grin)
Similar Threads: reinsert drain
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Feb 20, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
