How To Quick Clean Copper Fittings/Pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by molo, Apr 30, 2009.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Hi,
    I am wondering if there is a quick way to clean fittings and pipe. When I solder this is by far the slowest part of the process and I will be doing a lot of pipe repair this spring/summer.
    Thanks for any replies!
  2. hj
    tubing
    A brush chucked into a cordless drill will clean the fittings, but if you have that much copper to cut and clean, buy my electric copper cutter, cleaning, and reaming machine off Craig's list.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Oatey #95 flux
    [​IMG]
    Mill-rose open mesh sand cloth for the pipe
    [​IMG]
    and fitting brushes of which any will work but Mill-rose makes the best and you will pay more for them
    [​IMG]
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    For my DIY purposes, I use a brush for the fittings, and emery cloth for pipe ends. I do sometimes use the donut shaped brush for pipe, but a strip of emery seems to be easier to keep track of and it's easy to replace. I'm sure for a professional soldering day in and day out this would be a bit primitive.
  6. molo
    molo Member
    Sep 23, 2006
    Cold New York
    What city for Craigs List? I'm not sure how to find it.
    Thanks
  7. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
  8. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Great video. We haven't communicated yet, but I'm wondering how much I'll have to spend to get into one of these new or used.
  9. Gary Swart
    Sep 1, 2004
    Yakima WA
    I'm pretty sure HJ is in the Phoenix area.
  10. hj
    cutter
    Correct, but I will have to check to see if it is still listed. Does the same things the Rigid machine does.
  11. Cass
    Cass Plumber
    Nov 12, 2005
    Why are you selling it....
  12. KenC
    KenC New Member
    May 1, 2009
  13. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Personally, tho' it's a pain in the butt to clean copper I don't see the need to buy a machine to do it. For residental work I hold a piece of emery cloth around 3/4 and 1/2" copper pipe then roll it across my thigh with the palm of my hand. I couple of whacks that way it's ready to go. On big stuff, up to 3" It has always just been very quick to loop a long piece of emery cloth over the pipe and run around it like I'm polishing my shoe... I could do a half dozen by the time I could get a machine out and in place. A few spins of a good brush and I get the fittings done... not a big deal to me and I've probably soldered as many as 100 joints in a day.
  14. kingsotall
    Aug 17, 2008
    I suspect the OP has tendonitis or something that might impair their ability to prep copper the old school way.
  15. plumbingskool
    plumbingskool Retired Tradesman
    Feb 25, 2008
    Not Sure ;-)
    NY
    I guess he could use pex......that would avoid all the cleaning.....
    Or @The OP
    Yes, The best way is to spend time and do it right,
    There was this word we used in the 80's and some of the 90's
    "Craftsmanship".....That's what gets the fittings clean, That and some good Ole Fashioned Elbow grease
    Hope This helps:)
  16. molo
    molo Member
    Sep 23, 2006
    Cold New York
    After all the discussion I think I might try a drill chucked brush and the emery cloth. I guess it doesn't take that long and I don't have 100's of fittings, just dozens.
    Thanks for all the replies! :)
  17. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Use the ProPress and say goodbye to brushing:D
  18. kingsotall
    Aug 17, 2008
    That's what plungers...*ahem* "helpers" were invented for.
Similar Threads: Quick Clean
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Electric Water heater runs out quickly Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Hot water comes quickly but recirculating pump is off? Jun 15, 2016
Plumbing Forum, Professional & DIY Advice Quick vent question (near main stack) Mar 26, 2016
Plumbing Forum, Professional & DIY Advice Quick disconnects on Fixtures and PEX Jan 20, 2016
