How to manually clean a septic tank?
oliveol
Europe
I know this isn't going to be a nice job, and believe me, I've contacted numerous companies to see if they can come out and clean the tank, however I live fairly remote, and no one appears keen to come out to do the work...
I have a relatively small septic tank (I think around 1M3). I've noticed when I flush my toilet, there is a bad odour, which after a bit of googling, appears to mean the septic tank needs the solids emptying.
Lacking any better options, can I simply get a shovel, and remove the solids myself? Will this solve the issue? Anything I ought to be careful of, so as not to break anything?
GReynolds929
Active Member
WA
Generally septic tanks are pumped out with a vac truck. 250 gallons is a pretty small tank. Where does it drain to? Is there a drain field or is it a step system that drains into the sewer? I see that you're in Europe so not sure how the systems work over there.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
The "solids" are actually not all that solid and cannot easily be removed with a shovel. They are usually sucked out through a 2 - 4 inch hose with a vac truck.
sajesak
United States
Lacking any better options, can I simply get a shovel, and remove the solids myself? Will this solve the issue? Anything I ought to be careful of, so as not to break anything Maintenance contract services ellis county?
Before buying this place last summer, I had no experience of "private drainage"...
We have a two-chamber system of the concrete variety. the liquid outfall is to a "reed bed" insofar as it is an area of marshy ground infested with reeds...
:roll:
My main question (and there may be others
:wink:
) is what are the indicators that the tank(s) need emptying?
JohnCT
Still learning..slowly
Northeast
Manually? Pick up a phone and dial the number of a local septic company that can pump out your tank...
This is a really crappy job (sorry) and the equipment you need to do this right and the method of disposal is something you won't have access to. It doesn't cost that much to get it done.
John
LLigetfa
NW Ontario, Canada
:wink:
Do not rely on "indicators" as to when it needs to be emptied. If you wait for indicators, then it is already too late.
Open the covers on the the tank and probe the contents to see how deep the sludge is and how thick the floating scum is. If either of them are close to reaching the outlet baffle, it is time to pump it out. If either of them flow out of the tank into the leach field, then it is already too late as the damage is done.
