how to install a new valve body in tub and shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by don wagner, Jul 31, 2006.
  1. don wagner
    don wagner New Member
    Jul 29, 2006
    After removing and disposing of my old tub and shower fixtures, I discoved that the new valve body instructions show the water pipes coming up from the slab and connecting. My water pipes come down from the attic and I would have to turn the valve body upside down to install.Is that ok or will it mess up the way the water is diverted from tub spout to shower? This a three handle fixture.
    don
  2. jadnashua
    Some valves can flip their guts around. If you can't do that, your hot and cold would be reversed...best to just run the water around and come in from where it was designed.
  4. hj
    valve
    A three handle valve has a positive shutoff for the shower/tub ports so inverting it will not cause the problem with water from the shower head would if you used a diverter spout. If you use lever handles you will want to reverse them so they operate in the proper direction. The hot and cold will not be reversed. But, a three handle valve is no longer "legal" for a shower unless it has a pressure balancing unit installed with it.
Similar Threads: install valve
Plumbing Forum, Professional & DIY Advice pressure produced by pump with cycle stop valve installed Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Install traditional valve on CPVC/PVC pipe. Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Installing shower head far from valve Jun 12, 2016
Plumbing Forum, Professional & DIY Advice Shower valve install help May 24, 2016
Plumbing Forum, Professional & DIY Advice DIY Pressure Reducing Valve Install Questions Apr 25, 2016
