How to Handle Copper Toilet Flange Being too low to Tile Under
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Randy200, Aug 11, 2013.
  1. Randy200
    Randy200 New Member
    Aug 11, 2013
    Virginia
    Hi,
    I am remodeling an old bathroom and have ran into a situation I wanted to bounce off the experts in the forum.
    The build up is taking place on top of a 1.25" wood sub-floor. I have laid down the backer board on top of the wood. Then, put the tile on top of the backer board. As you can readily see, there is a perfect fit! That's exactly the problem, since there is no space for the two layers of needed thinset. Per my calculation I will need 2 layers of 1/8" thinset, for a total of 1/4" space!
    The flange is vintage circa 1960s. It is connected to cast iron piping, with access from below in the basement.
    Is it OK, if I tile flush or slightly below the flange, but not have the flange rest on top of the tile? If I do so, do I need to build up below the flange somehow, so the flange is resting on something?
    By the way, how would you go about cleaning the old wax off the flange?
    Thanks
  2. hj
    From here, it looks like it is attached to a copper pipe under the floor. I would use a #10 thick wax ring.
  4. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    This is a never ending debate. Flush with finished floor or on top of finished floor. In my opinion both are acceptable as long as flange is secure.
    Just find a way to clean it off.
  5. Randy200
    Randy200 New Member
    Aug 11, 2013
    Virginia
    Thank you. If I go the latter approach (tile butted next to the flange), How secure do I need to make the flange to the floor? Currently, there is about 1/2" space between the subfloor and the bottom of the flange (taken by the 1/4" durock and 1/4" tile in the picture). Should I
    1. Take the Backer board off and fill the 1/2" void with 1/2" plywood of some sort?
    2. Put thinset under backer board and keep them under the flange? Do I need to worry about the 1/8" void I will have left under the flange, since tile is not in there any more? Would bolting the flange down to the subfloor keep it "secure" enough?
    I suppose it will be OK, if the flange ends up being about 1/8" higher than the tile butted up next to it. It will get covered by the toilet, anyhow. ...
  6. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    You actually want the top of the flange above the finished floor, but if you don't accomplish that, you can use two wax rings or a #10 thick wax ring, as HJ says. Just make sure the flange is well-secured to the subfloor, because you are securing your toilet to the flange.
Similar Threads: Handle Copper
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Today at 6:03 AM
Plumbing Forum, Professional & DIY Advice How many plumbing fixtures can 3/4" supply handle Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
