How to drain my water pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rtfgvb, Feb 10, 2007.
  1. rtfgvb
    rtfgvb New Member
    Feb 10, 2007
    sorry if this is a newbie question, here goes...i am repairing a leaky joint in my copper water supply lines. i know that to drain the pipes i should shut off the water supply and open the highest and lowest faucets in the house. the leak is in the basement, which is unfinished. the lowest faucet in the house is still higher than the leaky joint. how do i drain this pipe?
    i have considered opening the drain valve at the bottom of the water heater. i would rather not haul that much water out of the basement, but is this my only option? thanks for any help...
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Where the piping rides along the joists between support hangers, jam a tool or piece of pipe betwen the pipe and the joist; this will drop a belly in the pipe long enough for it to pool and get the solder joint closed up.
    Be quick about it and don't waste time. That water will eventually fill the belly up and continue the way it was.....leak..
Similar Threads: drain water
Plumbing Forum, Professional & DIY Advice Where to drain water (condensation from HRV) Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice How to drain water out of pipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Pop-up drain refuses to hold water Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
