How many ground rods to install?
Discussion in 'Electrical Forum discussion & Blog' started by Washer Woman, Sep 1, 2007.
  1. Washer Woman
    Washer Woman New Member
    Jul 6, 2007
    We are buillding a house and have come to the electrical part. We will have 200amp service and are running the ground wire from the disconnect we have to have because the panel isn't back-to-back with the meter. My question is simply how many ground rods do we need? I've heard between 2 & 8 and this will be the difference of a bit of change at $8.50 ea. So just wanted your all's thoughts. Location is in the hills of West Virginia, up on a hill but trees on two sides if the matters. A fair amount of lightening. Thanks so much
  2. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    The NEC (National Electrical Code) requires one rod for if the tested reading for this one rod is below 25 ohms, they require a second rod a minimum seperation of 6 feet.
    Drive two 8 foot rods, the best installation would have a minimum of 16 feet between them, twice the length of a single rod.
    Are you planning on installing a lightning protection system, if so the LPS will have testing involved and minimum rods determined by this testing.
    Lastly where in the Mountain State?
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    If you don’t know how many ground rods to install it might be a good idea to seek help with wiring the house instead of doing it yourself.
  5. Washer Woman
    Jul 6, 2007
    So how much should I pay a professional to come to the house with their ground rod(s), clamps, wire and beater and do exactly what I can do while I sit and watch? What a condescending reply. And I actually know what our electric company requires I was simply wanting to know if more would be better. Thanks BrianJones to you for your reply, the mountain state is east of Ohio and west of Virginia!
  6. Cass
    Cass Plumber
    Nov 12, 2005
    The ground cable must be unbroken from the last ground rod to the panel reguardless of the number of ground rods, you can not use pieces, were you aware of that.
    jwelectric was not being condescending, we do not know your level of knowledge, expertise and ability. You could do something wrong that could cost you loss of property or life.
    He was being cautious and looking out for your safety by that comment.
  7. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Take a look at 'Wiring a House' by Cauldwell. He takes grounding very seriously. It is the first book I reach to when dealing with issues such as this. I still try to double check his book with the NEC, but thus far I have not found any contradictions.
    Steve
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Most areas require 2 rods, but feel free to pound in as many as you like...
  9. BrianJohn
    Jun 22, 2007
    VA
    Chris, if the area you live in follows the NEC two rods are not required if you follow the NEC and the results are less that 25 ohms, many/most electricians install two to avoid the hassle of testing.
    More rods may minimize potential lightning damage if a comprehensive Lightning Protection System is installed.
    I would consider installing a TVSS (Transient Voltage Surge Protection) at the Main Service.
    WW I am familiar with WVA, I live on the border with WVA (Charlestown) and owned land there for years (Hrdy County), just curious about the nearest town/city.
    I do not think JW was trying to be condescending it is an electrician thing, we feel only electricians can do OUR work....There are certain inherent dangers.
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Exactly... too much work to get a ground rod tested, easier to just drive another rod...
  11. BrianJohn
    Jun 22, 2007
    VA
    True especially for residential projects, even then you may not meet 25 ohms, depending on time of year, location..etc......
    Typically a 3 point test takes about 1-2 hours to perform properly, if you use an outside party to perform the testing (which many AHJs require) it runs about 350.00-650.00
  12. Washer Woman
    Jul 6, 2007
    Thank You all for your advice, BrianJones sorry, we are in Calhoun, it's nice to here from another WV person. The book that was mentioned by Cauldwell is actually the one that threw me when he says to put in eight rods. And we will be doing a surge arrester. Thanks again. Off to run cable.
  13. sbrn33
    sbrn33 Electrical Contractor
    Jul 9, 2007
    Fremont, NE
    Do you have the rebar in the foundation grounded? This is far more important than a couple ground rods. If you have copper water line coming in and the concrete encased electrode(rebar) you may not even need ground rods.
  14. hj
    ground rods
    You are building a house and a few $8.50 ground rods, if you needed more than two, would be a "deal breaker"? I tell people who are building houses that a $3,000.00 added expense is such a small percentage of the total project that it should be done if it makes the end result better.
  15. BrianJohn
    Jun 22, 2007
    VA
    HJ without doing some testing there is no proof that adding additional electrodes will buy you anything. In lousy soil conditions another 8' electrode can buy you .1 of an ohm.
    Ufer ground electrodes have been shown to be an effective ground electrode in dry conditions due to the concrete retaining moisture. I have always wondered if there is any reports from damaged footers due to lighting strikes?
    Lightning splits trees due to super heated sap exploding, concrete retains moisture the same damage is possible, I would assume?
Similar Threads: many ground
Electrical Forum discussion & Blog How many #6 wires in 3/4 inch rigid conduit? Jun 8, 2016
Electrical Forum discussion & Blog how many connections in baseboard heater? Oct 7, 2014
Electrical Forum discussion & Blog how many lights in a circuit as per code Oct 2, 2010
Electrical Forum discussion & Blog How many lights on a 15 amp breaker Mar 18, 2010
Electrical Forum discussion & Blog GFCIs in the service panel? How many circuits? Nov 23, 2009
