How long will "emergency" magic wrap tape last once applied
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jandn, Apr 10, 2007.
  1. jandn
    jandn New Member
    Mar 21, 2007
    Hi, a couple weeks ago I posted a question saying my tubs drain pipe was leaking when I flipped the switch which puts the stopper into hold water. Well, on a whim I wrapped the area I suspected the leak was coming from (go down the drain, it then bent 90deg to left and then into a vertical t-junction pipe.) I wrapped the bit where the pipe meets the T junction.
    I wrapped it using some "magic wrap" emergency air activated tape. Initally, about a half hour after wrapping the one area (I think it was coming from where the two pipes theaded together) it still leaked slightly through the tape. I thought it failed but tried it the next day and a bout a dozen times since then and it holds wonderfully.
    Question, any idea how long this tape lasts. It says emergency use on the box, but also says long lasting. Do you think I should just leave it on and wait until it fails again, before I call a plumber? The inital problem was a dripping of about a quarter cup of water everytime someone takes a bath (shower no problem) but baths are only run when my sisters kids come to visit which is only a couple times a year.
    Whats your experience with this tape.
    Thanks for any advice you can give.
  2. The old college try
    The old college try Engineering Technician
    Jan 31, 2007
    MO
    If this is the stuff I'm thinking of, I used it once on a radiator hose on my dad's van a few years back. The stuff actually lasted for a couple of years. Amazing stuff.
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    You are not dealing with any actual pressure there, so it might just last a long time ... and another possible "fix" would be the heavy, double-sticky rubber tape you can find in electrical departments. However, and since you can get to it to tape it, it would likely not cost any great amount to have that leaky drain replaced.
Similar Threads: long emergency
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Hot Water Takes Long Time for 2nd Bath Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Hot Mopping a shower How Long do you wait before Hot moping on new cement? Dec 2, 2016
Plumbing Forum, Professional & DIY Advice Sink drain question - long vs short 90 Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Ok to change this sanitary tee to a long sweep combo? Sep 10, 2016
