How do I trim an acylic tub surround?
Discussion in 'Remodel Forum & Blog' started by amblyn, Jan 25, 2009.
  1. amblyn
    amblyn New Member
    Jan 25, 2009
    We are remodeling an upstairs bath in our old farmhouse. The room is quite small but it was a full bath before and we want to keep it as a full bath. The issue is the bathroom has a sloped wall caused by the angle of the roofline. The bathtub/shower has a showerhead on the full height side but the opposite wall follows the roofline. It had tub surround panels that were probably installed in the 70's(marbled green laminate). We want to install an acylic surround - 3 or 5 piece - but will need to trim the back wall to height. Is this possible without completely ruining the surround? We aren't really interested in tiling this bath unless absolutely necessary. We are pretty handy but have never come up against this before. I have found a picture online that has a similar set up to our bath. If my desciption isn't clear I will try to copy it and post it. Any advice would be appreciated!
  2. CharlieM
    CharlieM New Member
    Jul 1, 2006
    Acrylic surrounds don't sit flat to the wall except for the screw flanges. IMO it would be impossible to trim one down which essentially removes the flange.
    I would tile it.
  4. jadnashua
    If you used solid surface panels, like Corian or Silestone (to name a couple), then it would be fairly easy. If you wanted to buy a conventional surround, I agree, it probably wouldn't work. You might be able to do it, but you'd have trouble making the edges look good, and you'd probably have to add blocking to support it since you'd be cutting off the lip that goes against the studs.
Similar Threads: trim acylic
Remodel Forum & Blog Triming Exterior Fiberglass Door Jun 13, 2011
Remodel Forum & Blog Air tight trim for recess lights Aug 3, 2010
Remodel Forum & Blog Vinyl PVC Trim Nov 16, 2009
Remodel Forum & Blog Ceiling Trim Problem Feb 20, 2009
Remodel Forum & Blog Recessed light trim will not stay tight to ceiling Nov 18, 2008
