How do i set-up my clack ws1.25?
Discussion in 'Water Softener Forum, Questions and Answers' started by MOVIE GUY, Jan 11, 2010.
  1. MOVIE GUY
    MOVIE GUY New Member
    Jan 11, 2010
    WICHITA
    I am in a new house with a clack ws1.25 valve, 18x33 brine tank, 10x54 mineral tank, 40k of sst=60 resin, city water @ 8 hardness. 2 people in the house. It seems to be using way to much salt?? Do I have to regenerate every 7 or 14 days? Why not every 30 days? Any down side to 30 days?
    That works out about right on my water use?
    please help and thanks........the Movie Guy
  2. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    For good life on your resin you should regenerate at least every 8 days. With your hardness, and I assume no iron or manganese, and assuming typical water usage of 60 gal per day per person your total hardness to remove every 8 days is 2 people x 60 gal/day/person x 8 grains/gal x 8 days =9680 grains. So I suggest you set your capacity to 10,000 grains, hardness to 8 grains, day override to 8, and set your salt dose to 3 lbs per regeneration. With these settings you should use approximately 3 lbs of salt per week and have soft water.
    I should note that in theory you could use a slightly lower salt setting with SST-60 resin but the settings above should provide you with consistent soft water and reasonalbe use of salt.
  4. Gary Slusser
    Retired
    A 10" x 54" is a 1.5 cuft softener, not 40K although you could program it for 40K of regenerated capacity. Doing so is going to get you very poor salt efficiency.
    And why a 1.25" control valve? You could have used 1.25" plumbing connectors on a Clack WS-1 valve.
    And you certainly didn't need to buy SST-60 resin with its serious increased price.
Similar Threads: set-up clack
Water Softener Forum, Questions and Answers correct order set-up for water softener and Carbon filter with backwash Aug 23, 2014
Water Softener Forum, Questions and Answers Clack WS1 regeneration question . . . Mar 5, 2017
Water Softener Forum, Questions and Answers Clack WS1 brine time Feb 13, 2017
Water Softener Forum, Questions and Answers No Brine Draw Clack WS1 Dec 10, 2016
Water Softener Forum, Questions and Answers Removing Clack Valve Dec 9, 2016
