PlumbIt
The contractors installed the drain inlet connector shown below (pic 1). Is it correct? A straight drain pipe (wall tube) with a removable compression fitting will not insert and connect to that inlet (pic 2). It will stay lose and fall out with minimal pressure. A pipe (wall tube) with a permanent flange on the end can be attached to the drain inlet and it stays tight (pic 3). Is that what I need to purchase? Do they come in various configurations (elbows, straight, etc.)?
