How do I get this flange off?
Discussion in 'Toilet Forum discussions' started by RobInMaine, Mar 10, 2012.
  1. RobInMaine
    RobInMaine New Member
    Mar 10, 2012
    Southern Maine
    My new-to-me house had a leaking toilet. I pulled all the rotted subflooring and now need to replace it. Is there some trick to getting a toilet flange off so I can lay the subfloor around the pipe? The new finish floor will be higher than the old floor, so the flange would also have to be raised a bit. Thank you in advance. The pipe appears to be copper and the flange brass or??
    [​IMG]
    [​IMG]
  2. hj
    You heat it with a torch until the solder melts, then pull it off. BUT, you will not likely find a longer flange, so you may have to extend the copper riser with a coupling and piece of pipe, or a new pipe into the elbow.
  4. RobInMaine
    Mar 10, 2012
    Southern Maine
    I've spent about 20 minutes trying to heat the pipe and all I have to show for it a half-empty bottle of propane and a few drips of solder. I think I need a bigger torch.....or a hacksaw....
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Since you will have to raise the flange anyway, why not cut the pipe off about 3" above the elbow. Then you can solder a coupler to that stub and the flange into the new coupler. A 4" joint is pretty hard to unsolder with a DIY torch. Problem is, you have compromised the joint already, so you may end up hiring a plumber to do this.
  6. hj
    YOU need a bigger torch and you have to keep the flame moving around the flange so the whole thing gets hot. It will work better if you heat the joint from inside the pipe.
  7. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Use two torches one on each side and move them around. You could pay a plumber cheaper than buying a torch designed to solder 3" copper.
Similar Threads: flange
Toilet Forum discussions Toilet Flange not Flat/Level Feb 21, 2017
Toilet Forum discussions Urine Smell and Rusted Flange Washer Feb 20, 2017
Toilet Forum discussions Sealing offset flange Feb 12, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Sani Seal with Offset Flange 1/4" Above Tile Floor Jan 5, 2017
