How can I increase the temp of my Mix-it valve.
Discussion in 'Shower & Bathtub Forum & Blog' started by Gabe, Nov 16, 2008.
  1. Gabe
    Gabe New Member
    Nov 16, 2008
    I had a new bathroom built in June. All new construction. I noticed that the hot water in the shower is not as hot as the sink. The contractor installed a new Delta mix-it valve. I turned up the temperature at the water heater as instructed by the plumber but there is no real change. What should I do to get the water temperature to increase. :confused::confused:
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It would help if we knew which Delta Mixit valve you have...
    Can you post a pic?
  4. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Behind the handle there is going to be a temp limit/ scaldguard stop. adjust it to allow the handle to turn further to the hot position
  5. hj
    valve
    Delta and Mixet are two different companies. Mixet is out of business so I hope you do not have one of those in a new shower.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Thats what I was thinking...
    A pic would help....
  7. Gabe
    Gabe New Member
    Nov 16, 2008
    Delta T13120 Classic Single Handle Tub Trim Chrome
  8. Redwood
    Dec 15, 2007
    Service Plumber
  9. Gabe
    Gabe New Member
    Nov 16, 2008
    Thanks!! problem resolved!!!
Similar Threads: increase temp
Shower & Bathtub Forum & Blog Shower/Tub loses pressure as hot water temp increases Oct 21, 2010
Shower & Bathtub Forum & Blog Shower pressure dropped and noise increased Jun 7, 2014
Shower & Bathtub Forum & Blog How to increase water pressure/flow in showerheads Feb 9, 2013
Shower & Bathtub Forum & Blog ok to increase number of turns in gal steel supply? Jul 23, 2006
Shower & Bathtub Forum & Blog Moen Posi-Temp Banbury Model One Handle Tub/Shower Faucet - New install, hard to turn Feb 1, 2016
