Hot water expansion tank
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mikebarone, Feb 4, 2008.
  1. Mikebarone
    Mikebarone DIY Senior Member
    Feb 19, 2006
    Phoenix, AZ
    I have a client that has a home that has two electric hot water tanks. One tank does one half of the house, and the other tank does the other half of the house. Recently, she had a plumber install a pressure reducing valve on her house and, (because of what I’ve learned on this great forum) she now has a closed system and she needs an expansion tank. The PRV is set at 60 psi. My question is, do I need to install two expansion tanks, (one for each hot water tank) or could she get away with just one tank on the incoming cold water line, (after the PRV) like by her water softener?
    Thanks all,
    Mike
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    One tank would be sufficient, but I would opt for the larger size. Install it between the PRV and the first water heater.
  4. Mikebarone
    Feb 19, 2006
    Phoenix, AZ
    Thanks
    Thanks Gary. The Home depot by my house only sells one size, (ie one tank for one hot water tank). I will get on the web site that makes the tank, and see if I can get the next size.
    Thnaks again,
    Mike
  5. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I would just watch the price with shipping, it might be cheaper to go with the two expansion tanks. Also size does matter so be sure you get them to size it if you order one.
  6. jadnashua
    I think it is Watts that has an expansion tank size calculator on their website. You enter the size of the WH(s), the expected temperature rise, and it tells you what size tank you need. They usually come precharged with 40# in them, if your PRV is set to 60, you'll need to add some air to it.
  7. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Hot Water Tank
    You need two expansion tanks, one on each water heater,
    BETWEEN THE COLD SHUT OFF ON EACH HEATER ! ! !
    otherwise the tank can be isolated by any shut off's in system,
    and still pressure bulge or blow up without expansion protection:D
    JERRYMAC MASTERPLUMBER
    PH.D WATER HEATEROLGY ! !
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Our resident PH.D Waterheaterologist is correct! I was scrolling down to post the same thing when I saw his post.
  9. Gary Swart
    Sep 1, 2004
    Yakima WA
    Thank you for that information Dr. Jerry Mac. I stand corrected.
  10. Mikebarone
    Feb 19, 2006
    Phoenix, AZ
    All good points...thanks!!!
    As usual, I want to thank everyone for all of the great inputs. I tell everyone how great this forum is. You all make this handyman look somewhat intelligent….LOL!
    This poor lady’s house was build by her ex-husband, and you wouldn’t believe some of the, “short cuts†I’ve found in the past three years I’ve been working for her. The first day I went to work for her, I was just going to replace a bad started switch on her outside stainless steel BBQ. After I noticed that the back of the switch was melted, (and I found that three of the six gas valves were leaking), she had me there for a total of 12 hours that day fixing other things…LOL…and I’m not done yet!
    Thanks all again,
    Mike
  11. Cass
    Cass Plumber
    Nov 12, 2005
    According to the Watts info here
    http://www.watts.com/pdf/ES-PLT.pdf
    The Watts PLT-12 (large tank) will handel up to 120 gallons being heated / expanded at a water pressure of 60 PSI.
    2 expansion tanks is a good idea but not necessary, I have been in very few homes that have a valve between the main and the water heater or heaters valve.
  12. hj
    heater
    If that did happen then she also had a defective, nonfunctional temperature/pressure relief valve, AND if so, and conditions were such that a blow up could occur, all the expansion tanks in the world would not prevent it.
  13. MASTERPLUMB777
    Aug 6, 2007
    Texas
    Hot Water Tank
    :D
    It's called murphys law ! !
    it should be installed between cold shut off and tank,
    if do'es not have this protection voids MFG'S warrenty on leaking tanks
    JERRYMAC MACPLUMB 777:)
  14. Mikebarone
    Feb 19, 2006
    Phoenix, AZ
    Good point!!!
    Thanks, Mike
Similar Threads: water expansion
Plumbing Forum, Professional & DIY Advice Expansion tank leak, can I keep water heater off? Mar 19, 2016
Plumbing Forum, Professional & DIY Advice Recommendation for small expansion tank for potable water recirculation loop Jan 12, 2016
Plumbing Forum, Professional & DIY Advice Without an expansion tank, is something happening to our water heater? Mar 22, 2015
Plumbing Forum, Professional & DIY Advice Expansion Tank & System Pressure After New Water Heater (Rising Pressure) Dec 19, 2014
Plumbing Forum, Professional & DIY Advice Expansion Tank and Water Hammer Arrester Jan 7, 2014
