Hot water doesn't last
bajaboy1
KY
I know this question has been asked many times, but the solutions haven't helped me as of yet.
Culprit: 2001 AO Smith gas 40 gallon water heater.
Problem: Hot water only lasts about 10 gallons. Luke warm after 11 and getting cold at 12.
I've cleaned the tank.
I've replaced the dip tube (which was fine).
I buttoned up the air so I have no leaks, have a nice blue flame.
Any advise appreciated.
bajaboy1
KY
To add.
Water heater turns back on after 5 gallons used.
Thanks
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Culprit: 2001 AO Smith gas 40 gallon water heater..
That puts it at 11 years old. Maybe it looks like this on the inside.
bajaboy1
KY
I suppose it could! I've flushed it since new a few times a year though.
Last guy that had this problem found a leak in the pipes under the house. It doesn't take much to minimize the hot water available. Do you get warm water at any other faucets in the house? A defective faucet that's creating a cross-over can limit the amount of hot water available, too.
bajaboy1
KY
No leaks anywhere. It happens at any shower or faucet in the house. Should the water heater turn on sooner?
bajaboy1
KY
Could the temp probe be scaled up or bad causing issues? Only thing I haven't checked or changed.
Gary Swart
Yakima, WA
While just replacing things on the chance that that piece/part might be the problem isn't a very sound method, in this case, an 11 year old water heater is likely about served out its life anyway. The A O Smith is not a favorite heater among the plumbers on this forum, so that might also be a good reason the get a new heater. If that doesn't fix the problem, then of course you'll have to look elsewhere, but the heat is really about due anyway.
bajaboy1
KY
I thought they were good till they start leaking, rusting out. What else goes bad on the inside to prevent heating up? And thanks all.
And what brand do you recommend?
Mineral deposits can deplete the volume and act like a big insulator. The 'average' WH probably only lasts 6-8 years. Yes, some can last much longer than that, but for practical purposes, at 11, if it's not working properly, it probably isn't worth mucking with. FWIW, often, the only difference in a longer warranty is (maybe) a better sacrificial anode and the warranty...it's often the same tank, you're only paying the insurance betting it won't last that long.
bajaboy1
KY
See the pic.Didn't think that was "normal" when you take care of it.
So I need a new one. Mine has the power vent on it, no chimney. I suppose this is just a regular water heater with the power vent, correct? Can be reused on another heater?
Thanks again
DonL
Houston, TX
If the water comes out Hot in the first place then it must be heating.
The mixing of cold coming in to hot going out will affect the Output Temperature.
The gas will not heat the water as fast as you can use it with Hot wide open.
Most people add some cold water to the hot and can take a normal shower.
If your recovery is slow, than that is a different problem.
Maybe your thermocouple is out of gas.
May be time for a new heater.
wassermeister
portland, OR
It may not be your water heater after all that's causing the issues. What are your water pipes made of? If you have galvanized pipes or are using well water you may have junk in the pipes that restrict proper flow.
Jimbo
San Diego, CA
Thanks again
Oh NO NO NO! A power vent water heater is built and UL listed as such. It will cost you more. NEVER attempt to modify a WH in any way.,
bajaboy1
KY
Yes, have since found that out. Thanks. Looks like I may go electric since I have that option. Can't see spending $1000 on a power vented.
Kentucky might have access to fairly cheap TVA power, but in most places, a gas WH is 1/3 or so of the cost to heat water verses electric, so factor that into your expected payback analysis.
