Hot Tub Installation
Discussion in 'Electrical Forum discussion & Blog' started by bobpat, Mar 31, 2009.
  1. bobpat
    bobpat New Member
    Mar 30, 2009
    Retired Manufacturing Engineer
    Western New York
    I have a few questions about running a 240 v 60 amp service for a Hot Tub.
    My service panel is located in the basement and the Hot Tub will be on my deck attached to the house. The run in the basement is 30 ft, to where I go thru to the outside under my deck then another 15 ft to the tub. My plan was to run 6/3 ROMEX® from my panel to a weather-tite "J" box then use #6 THHN (4 wires 2 hot, 1 neutral, 1 ground) in PVC conduit to a weather-tite SPA panel with a 60 amp GFCI located within 7 feet of the Hot Tub, then the use liquidtight, flexible nonmetallic conduit to the Hot Tub.
    My concern is: Do I need to have an insulated ground from the Hot Tub back to my main panel in the basement or just to the SPA panel that is located 7 ft from the Hot Tub? If so then I would need to use THHN in conduit all the way.
    Also if I can use 6/3 ROMEX® in the basement, the bear ground in 6/3 ROMEX® is only 12 AWG. Will this be an issue with proper grounding?
    Thanks
    Bob
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    You must use conduit and individual conductors for the outside portion of the wiring. This part must have an insulated ground. You can come into the back of the weatherproof box with the NM cable where you change over to PVC conduit.
    The inside portion can be NM cable and the bare #10 ground is fine.
    Keep in mind you can only have 6' of flexible. Use some rigid PVC to get closer to the tub then change over to sealtite.
  4. bobpat
    bobpat New Member
    Mar 30, 2009
    Western New York
    Thank you very much for the help.
    Bob
  5. bobpat
    bobpat New Member
    Mar 30, 2009
    Western New York
    When I mount the disconnect for the hot tub, what is the recommended height?
    thanks
    bob
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    If you are under the 2008 code cycle and the circuit is protected with a 60 amp overcurrent device then #6 will not pass, the NM will need to be #4.
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Why is that?
Similar Threads: Installation
Electrical Forum discussion & Blog Electric baseboard installation: no junction box behind it? Nov 25, 2016
Electrical Forum discussion & Blog Transfer switch installation Sep 27, 2016
Electrical Forum discussion & Blog Three Way Switches Light Dimmer Installation May 1, 2016
Electrical Forum discussion & Blog Service Upgrade & Sub Panel Installation Apr 17, 2015
Electrical Forum discussion & Blog Voltage/Current Panel Meter Installation Oct 17, 2014
