Hose bib wiggles : how to fix ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rime, Apr 7, 2011.
  1. Rime
    Rime New Member
    Oct 11, 2010
    California
    One of my outside hose bibs wiggles whenever I press on it ( yes, I know, I shouldn't do that ! ) or when I'm attaching the hose or moving the hose about. I have visions of the wiggle stressing the pipe it's attached to, breaking a soldered connection, and creating my very own private waterfall ( in the wall where I can't enjoy it :-( ) Is there anything I can do to stabilize the bib ? It's just a piece of copper pipe sticking out of the wall with the hose bib soldered on.
    Thanks !
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You're not going to break the solder connection, but you could bend the pipe. There should be a collar on the hose bib that has holes or slots for screws that would anchor the bib to the side of the house. If this is not what you have, you might go inside the house and fasten a clamp that would hold the bib tight against the house. A clamp that is normally used to attach a ground wire to a pipe would work. I'm not sure of the proper name for it, probably something like "grounding clamp" would give a clerk a clue.
  4. hj
    The TYPE of "hose bibb" you have and its connection would determine how we would answer your question, so a picture would be very helpful.
Similar Threads: Hose wiggles
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Hose Bib Bonnet Packing Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Single valve for multiple outside hose bibs Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
