high temp flow reducer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by RoDa, Jul 15, 2009.
  1. RoDa
    RoDa New Member
    Jul 9, 2009
    I posted this question in the solar forum, but it didn't get many eyes, so I figured I'd try again here.
    I'm looking for a flow reducer that will stand up to high temps (water from my solar array is around boiling), but all the ones I've found so far have max temp ratings of about 70 C. I need a flow reducer, as the system calls for about 2gpm, and the circulation pump at the lowest speed put out about 6 gpm (too high a flow rate, and the water doesn't reach max temp in the array).
    Can anyone suggest a source for a high temp flow reducer?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Here is a Boiler Trim Valve that should work for your needs. http://www.yarway.com/hy-drop.asp
    Or you can go for something a bit more expensive. http://www.tycoflowcontrol-na.com/products_results.asp?Selection=Control+Valves&m=1
Similar Threads: high temp
Plumbing Forum, Professional & DIY Advice Is there a special shut-off for higher than WH temp water? Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Higher temperature water heater overflow valve? Jan 30, 2013
Plumbing Forum, Professional & DIY Advice LOW Temp or HIGH Temp AQUASTAT for WH? Mar 27, 2010
Plumbing Forum, Professional & DIY Advice Two HW heaters or higher temp w/mixer? Nov 2, 2007
Plumbing Forum, Professional & DIY Advice Water Heater High Temp Override Dec 18, 2006
