High-pitched noise from water heater
Karen F.
Arkansas
My American electric hot water heater (with expansion tank) makes a high-pitched noise when outside spigots are only partially open. This happens with the dishwasher also as I guess there's restricted flow there as well. I've flushed the tank which didn't help and checked the tpr valve which appears to be working fine.
I'd appreciate your thoughts on what the problem could be.
On some valves that utilize a washer to seal, as the washer starts to age, it can loosen and vibrate (the rubber can shrink or otherwise deteriorate and the screw doesn't hold it tight). There's potentially a bit more turbulence when partially open than fully open. That can make a high pitched sound, but there are probably other things that can as well.
The dishwasher's inlet valve typically doesn't use a washer, but there's probably a shutoff under the sink that feeds it, so that could be the culprit there. It's more common today to use a 1/4-turn valve that doesn't have a washer that can vibrate, and if it's the DW, and it's a multi-turn one, swapping that out for a new one might solve that issue. On the hose bib, maybe replacing the existing washer might solve that. Both of them are inexpensive unless you have to hire a plumber to do it for you.
Water heater makes noise? close valve just to be sure water heater shouldnt make noise when running cold water. Check pressure cant say exactly why but Id check it because I have gage and it takes less than a minute
Karen F.
Arkansas
Thanks for responding! Strange, it always happens with the spigot I use to water the garden... until today. Today while watering the water heater was silent. It now appears to be an intermittent issue. The valve that turns the water off in the water heater closet does that need to be checked? The sound is coming from somewhere in this closet. I cannot tell exactly where in this closet.
Karen F.
Arkansas
I'm going to buy a pressure gage today. Perhaps the incoming water pressure is too high and the pressure regulator needs to be adjusted.
Yes try some differant things. I cant see why W/H makes noise when running cold water . thats why I said close valve on water heater as I dont think noise is coming from there but just guessing. Checking pressure is another thing . Otherwise If we dont do something , we can do nothing but these are easy things to try
